Salve a tutti, sto cercando di far comunicare il mio arduino nano ad un modulo hm10 (zs040).
Ho collegato tutto correttamente(o almeno credo) ma quando do il comando AT non mi ritorna nulla. Il modulo viene riconosciuto correttamente dal cellulare e riesco anche a fare il pairing.
Questo è il codice che sto utilizzando:
// SerialIn_SerialOut_HM-10_01
// Uses hardware serial to talk to the host computer and AltSoftSerial for communication with the bluetooth module
// What ever is entered in the serial monitor is sent to the connected device
// Anything received from the connected device is copied to the serial monitor
// Does not send line endings to the HM-10
// Pins
// BT VCC to Arduino 5V out.
// BT GND to GND
// Arduino D8 (SS RX) - BT TX no need voltage divider
// Arduino D9 (SS TX) - BT RX through a voltage divider (5v to 3.3v)
#include <AltSoftSerial.h>
AltSoftSerial BTserial;
// https://www.pjrc.com/teensy/td_libs_AltSoftSerial.html
char c=' ';
boolean NL = true;
Serial.print("Sketch: "); Serial.println(__FILE__);
Serial.print("Uploaded: "); Serial.println(__DATE__);
Serial.println(" ");
BTserial.begin(9600);
Serial.println("BTserial started at 9600");
// Read from the Bluetooth module and send to the Arduino Serial Monitor
if (BTserial.available())
c = BTserial.read();
Serial.write(c);
// Read from the Serial Monitor and send to the Bluetooth module
if (Serial.available())
c = Serial.read();
// do not send line end characters to the HM-10
if (c!=10 & c!=13 )
BTserial.write(c);
// Echo the user input to the main window.
// If there is a new line print the ">" character.
if (NL) { Serial.print("\r\n>"); NL = false; }
Serial.write(c);
if (c==10) { NL = true; }
Qualcuno potrebbe aiutarmi?
Grazie!
ps: ho utilizzato questa guida
