I try to program an Arduino Nano clone: the chip is the CH340G.
I have installed the windows driver prior connecting the Nano and prior opening the Arduino IDE.
In the Arduino IDE (version 1.8.6 on W10 64 bits) I have selected "Arduino Nano" in the list of cards, and the Port COM5 as it appears to be the right one.
The Nano has 2 Leds: one is permanently ON and the second one is flashing.
When I try to upload my program, it seems that the Nano is not responding, because I get the following error:
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg WunschSystem wide configuration file is "E:\Programmes\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM5
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x0b
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x0b
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x0b
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x0b
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x0b
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x0b
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x0b
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x0b
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x0b
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x0bavrdude done. Thank you.
Problème de téléversement vers la carte. Voir http://www.arduino.cc/en/Guide/Troubleshooting#upload pour suggestions.
Can you help me ?
There is no exclamation mark in the Device Manager, although I do not see any CH340 device, maybe it is normal, maybe I have not look in the appropriate section.
Thank you
