I use an arduino nano clone and I see it has a voltage regulator "Ams1117 5.0 h517" in it. As I understand this regulator provides a steady 5V. But my arduino also has a 3.3 V output pin and I cant find the voltage regulator of 3.3 V in it.
The thing is this: I am using 3.3 V of arduino to power nrf24l01+ and as far as I know this 3.3 V provided by arduino is a shitty voltage, it is not steady. So I would like to find the 3.3 v voltage regulator on the arduino board and replace it with a better one. But I cant find it on the board. My arduino is this http://produto.mercadolivre.com.br/MLB-704730199-arduino-nano-30-tutorial-em-portugus-_JM
Thanks for the link, but that only shows the top side. The voltage regulator and the usb-serial chip are on the back.
In the official Arduino Nano, the FTDI usb-serial chip creates the 3.3V, that 3.3V is not very strong.
In the Arduino Nano clones, a counterfeit FTDI is often used, I don't know how good or bad that 3.3V is.
The NRF24L01+ might need a burst of current, you could add a 3.3V voltage regulator (a LDO type).
It states it uses a CH340. It's a fine Serial to USB converter. Like the FTDI it has a 3,3V regulator build in.It's fine for logic but cant deliver much like for transceivers. So you just have to add your own regulator
Thanks man But I almost never use my arduino powered by USB, I usually power my arduino providing 12v at VIN. So where is the regulator? Do you know the current limitation?
Like I said, there is non! It's inside the CH340 USB to serial. And that chip is just connected to Vcc which can be the output of the 5V regulator or the USB.
