Hello everyone, as I'm new here. I'm not very experienced so please be patient if answer to my question is trivial, however I cannot find it myself, even though I have tried hard.
I have a problem with my Arduino Nano 328P (a clone actually, marked as "Deek-Robot NANO V4.0"). I have created a sketch and succesfully uploaded it, but the problem appeared when I tried to update it - during upload Arduino IDE either says that COM port is already in use (if I connect Arduino after starting IDE) or Java process crashes (if it is connected before starting IDE). I'm sure that this is because I messed with RX, TX pins. In my project I need all possible digital pins and I had to use also D0 and D1. THe relevant part of my code is:
void setup(){
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
delay(300);
pinMode(A0, OUTPUT);
pinMode(A1, OUTPUT);
pinMode(A2, OUTPUT);
pinMode(A3, INPUT);
pinMode(0, OUTPUT);
pinMode(1, OUTPUT);
pinMode(A5, OUTPUT);
pinMode(A4, INPUT);
// here some reading from pins A3 and A4, and writing to A0, A1, A2, A5, 0 and 1
Did I disabled possibility to program Arduino through USB? What are my options now? Please post some answers or direct me to a tutorial if there is any.
you can use analog input pins as digital by the statement pinMode(Ax, OUTPUT); (Ax is A0,A1,...). Then free up the RX and TX pins for upload and communication.
You can use as written - to download: press & hold the reset button, when the IDE shows "compiled xxx of 32xxx bytes" release the reset. Might take a few tries to get the timing right. Also easier if you do File:Preferences and turn on Verbose outputs.
The reset makes sure the bootloader is ready for the downloa and that the sketch hasn't started already to interfere on the serial lines.
@groundfungus
As you can see in my sketch, I'm already using analog pins as digital outputs, and even though it's not enough. Using a shift register is not an option too, beacause I need ability to switch outputs with frequency up to 1 MHz, so I won't have time to transmit data serially. Besides, my problem is not the code, but the fact that I don't have access to my Arduino.
@CrossRoads
I tried that already, but it seems that the key is timing. I'll try your advice and turn verbose output on. Thanks!
Also, for the future - what should I do to avoid such situation? As you can see, I've put 300ms delay, but it is clearly not enough.
OK, problem solved. I aquired USBasp programmer and reburned bootloader. After few experiments (and few sequential reburns) I found out, that 1800 ms delay on startup allows to use D0 and D1 as outputs without blocking ability to reprogram normally through USB.
