I am working on a simple MP3 program using the Arduino Nano. However, after a few successful uploads using the Arduino IDE, I started encountering an error.
I have tested multiple Arduino Nano boards, different USB ports, and various cables. I also tried using VS Code instead of the Arduino IDE, but I keep encountering the same error in every case.
I believe the issue isn't with the hardware, cable, or the IDE, but rather with a driver, a Windows update, or something related to my laptop. Has anyone experienced the same problem? Can anyone help me?
Sketch uses 4704 bytes (15%) of program storage space. Maximum is 30720 bytes.
Global variables use 432 bytes (21%) of dynamic memory, leaving 1616 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xae
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xae
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xae
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xae
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xae
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xae
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xae
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xae
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xae
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xae
Failed uploading: uploading error: exit status 1
