I used D5 D6 D7 D8 D9 D10 D11 D12 for keypad.
I now want to add an ethernet module using SPI so need to move at least D12 D11 D10.
Can I use 4 of the keypad on D5 D6 D7 D8 and other 4 on A0 A1 A2 A3 without any problems by using
byte rowPins[ROWS] = {A3, A2, A1, A0};
byte colPins[COLS] = {8, 7, 6, 5};
The above connections should be alright as (by default) A0 - A3 pins are digital pins. These pins become analog pins when the ADC Module is activated by programming the ADEN-bit.
Again: For NANO --
A0 - A5 pins are digital pins by default (after power).
A6 - A7 pins are analog pins and are connected with the internal ADC. These two pins cannot be used as digital IO pins.
Yes Ive been looking at that as my next method and for future projects will probably try and utilise it for control but im just getting back into projects after a long break and just jumped straight into it without knowing where i wanted to take this project
