Arduino nano crashes randomly
I'm working on a project just for fun which consists in a desktop fan made with a noctua pwm fan and an arduino nano to control it, the fins, turn off timer, etc.
The setup consists in an Arduino Nano (328p with old bootloader), HDC1080, 9g servo, ir receiver, OLED 128x64 and the noctua fan. (Schematic shared below)
The thing is, the code works perfect (while it does) until after some seconds/min it just stops responding. It is not a fixed time, it's just random.
I have been trying to fix this crash issue but I don't know what else to try.
This is my code: (sorry for the spanish comments)
//Incluimos las librerias necesarias
#define DECODE_NEC              //Definimos el protocolo de comunicacion IR (debe hacerse antes)
#include <IRremote.hpp>         //Librería IR
#include <Adafruit_SSD1306.h>   //OLED
#include <Adafruit_GFX.h>
#include <ClosedCube_HDC1080.h> //HDC1080
//#include <Adafruit_CCS811.h>    //CCS811
//Definimos variables
#define irPin 4             //Pin IR receiver
#define fan_control_pin 9   //Pin FAN
#define pinMosfet 3         //Pin mosfet
#define tach 5              //RPM pin
unsigned int rpm;           //Variable donde se guardan las RPM calculadas
byte servoPin;              //Variable donde se guarda el pin del servo motor
float servoPos;             //Posicion del servo
byte isMovement;            //Flag para marcar movimiento pendiente
#define servoSpeed  5       //Velocidad del movimiento(menor es mayor)
float posSmooth,posPrev;
float temp,hum;
#define tempHum_updateInterval 5000 //Tiempo de actualizacion en ms
  //CONFIGURACION SERVO
  #define servo_Pin 2         //Pin del servo motor
  #define servo_MED_POS 150   //Definimos la posicion horizontal de las aletas (en grados, de 0 a 180). En esta posicion se enciende el sistema.
  #define servo_MAX_POS 160   //Posicion max
  #define servo_MIN_POS 120   //Posicion min
  #define servo_CLOSED_POS 100//Posicion cerrado
  #define servo_CHANGE_POS 10 //Delta posicion en grados
  #define swingSpeed 200      //Velocidad de barrido de las fins
  #define posStep 2           //Cambio posicion de barrido
byte fanSpeed; //En %
  //CONFIGURACION VENTILADOR
  #define fan_CHANGE_SPEED 25 //Porcentaje de cambio en la velocidad del ventilador por pulsacion en el mando
  #define fan_START_SPEED  50 //Velocidad inicial del ventilador en %
  #define TEMP_CUTOFF 25      //Temperatura para la que el ventilador ya no es necesario y se puede apagar (MODO AUTO)
  #define TEMP_MAX_SPEED 32   //Temperatura para la que el ventilador se pone al 100% (MODO AUTO)
unsigned long tiempo,time,tiempo2,tiempo3,tiempo4,tiempo5,tiempo6,tiempo7,currentMillis; //Contadores de tiempo
bool powerState = 0;                               //Marcador de encendido/apagado
bool isSwing = 0;                                  //Marcador del movimiento de fins
bool initMode;                                     //Marcador del estado de los fins al inicio (subir o bajar)
bool isScreen = 1;                                 //Marcador para encender o apagar pantalla informativa
bool isAuto = 0;                                   //Marcador para el control automático del ventilador
bool timerMode = 0;                                //Marcador para el modo con temporizador
bool timeChange = 0;                               //Marcador para permitir cambio del tiempo restante
unsigned long setTime = 0;                         //Valor del temporizador
byte horas,minutos;
#define timerStepInterval 30                       //Cambio por pulsacion en el temporizador (minutos)
//Definimos la frecuencia de la señal PWM
const word PWM_FREQ_HZ = 25000;                   //Ajustar este valor para ajustar la frecuencia
const word TCNT1_TOP = 16000000/(2*PWM_FREQ_HZ);
//OLED
#define ancho 128
#define alto 64
#define OLED_RESET 0
Adafruit_SSD1306 oled(ancho, alto, &Wire, OLED_RESET);
//Tamaño de letra
#define tam 1
//Fuente de letra
#include <Fonts/FreeSans9pt7b.h>
//CCS
//Adafruit_CCS811 ccs;
//HDC1080
ClosedCube_HDC1080 hdc1080;
//Añadimos los iconos de temperatura y humedad
//Humedad(TAM 20,25)
const unsigned char PROGMEM humLogo[] = {
  0x00,0x40,0x00,
  0x00,0x40,0x00,
  0x00,0xA0,0x00,
  0x00,0xA0,0x00,
  0x01,0x10,0x00,
  0x01,0x10,0x00,
  0x02,0x08,0x00,
  0x02,0x08,0x00,
  0x04,0x04,0x00,
  0x04,0x04,0x00,
  0x08,0x02,0x00,
  0x08,0x02,0x00,
  0x10,0x01,0x00,
  0x10,0x01,0x00,
  0x20,0x00,0x80,
  0x20,0x02,0x80,
  0x20,0x02,0x80,
  0x20,0x04,0x80,
  0x10,0x09,0x00,
  0x10,0x31,0x00,
  0x08,0x02,0x00,
  0x06,0x0C,0x00,
  0x01,0xF0,0x00,
  0x00,0x00,0x00,
  0x00,0x00,0x00
//Temperatura(TAM 20,25)
const unsigned char PROGMEM tempLogo[] = {
  0x00,0x00,0x00,
  0x00,0x60,0x00,
  0x00,0x90,0x00,
  0x01,0x08,0x00,
  0x01,0x0F,0x00,
  0x01,0x0F,0x00,
  0x01,0x08,0x00,
  0x01,0x0F,0x00,
  0x01,0x0F,0x00,
  0x01,0x08,0x00,
  0x01,0x08,0x00,
  0x01,0x08,0x00,
  0x01,0x08,0x00,
  0x02,0x04,0x00,
  0x02,0x04,0x00,
  0x04,0x02,0x00,
  0x04,0x02,0x00,
  0x08,0x01,0x00,
  0x08,0x05,0x00,
  0x08,0x05,0x00,
  0x08,0x09,0x00,
  0x04,0x12,0x00,
  0x04,0x62,0x00,
  0x02,0x04,0x00,
  0x01,0xF8,0x00
//Power logo
const unsigned char PROGMEM powerLogo[] = {
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x07,0xFF,0xF9,0xFF,0xFE,0x7F,0xFF,0x9F,0xFF,0xE0,
//Añadimos en primer lugar las funciones necesarias
//Funcion para PWM freq
void setPWMfreq()
  // Clear Timer1 control and count registers
  TCCR1A = 0; // undo the configuration done by...
  TCCR1B = 0; // ...the Arduino core library
  TCNT1  = 0; // reset timer
  // Set Timer1 configuration
  // COM1A(1:0) = 0b10   (Output A clear rising/set falling)
  // COM1B(1:0) = 0b00   (Output B normal operation)
  // WGM(13:10) = 0b1010 (Phase correct PWM)
  // ICNC1      = 0b0    (Input capture noise canceler disabled)
  // ICES1      = 0b0    (Input capture edge select disabled)
  // CS(12:10)  = 0b001  (Input clock select = clock/1)
  TCCR1A |= (1 << COM1A1) | (1 << WGM11);
  TCCR1B |= (1 << WGM13) | (1 << CS10);
  ICR1 = TCNT1_TOP;
} //setPWMfreq
void setPWMDuty(byte duty)
  if(duty == 0)
    analogWrite(pinMosfet,0);
    analogWrite(pinMosfet,255);
    OCR1A = (word) (duty*TCNT1_TOP)/100;
  //Serial.println(duty);
} //setPwmDuty
int getRPM()
 time = pulseIn(tach, HIGH);
 if(time == 0)
 { rpm = 0; }
 { rpm = (1000000 * 60) / (time * 4); }
 return rpm;
} //getRPM
void moveServo(float pos)
  isMovement = 1; //Marcamos que se ha solicitado movimiento
  //Suavizamos el movimiento
  pos = pos * 100;
  posSmooth = (0.20*pos)+(0.80*posPrev);
  posPrev = posSmooth;
  //Mostramos en terminal valores (Debugging)
  //Serial.print("Pos: ");
  //Serial.println(posSmooth/100);
  //Serial.println(pos/100);
  //Comprobamos si ha terminado el movimiento
  if(abs(pos-posSmooth) <= 3)
    isMovement = 0;
    //Serial.println("Terminado");
  //Movemos el motor
  softServoWrite(posSmooth/100, 0);
//Funcion SERVO sin uso de timers
void softServoAttach(byte pin)
  servoPin = pin;
  pinMode(pin, OUTPUT);
//Writes given angle to servo for given delay in milliseconds
void softServoWrite(int angle, long servoDelay)
  int pulsewidth = map(angle, 0, 180, 544, 2200); // width in microseconds
  do {
    digitalWrite(servoPin, HIGH);
    delayMicroseconds(pulsewidth);
    digitalWrite(servoPin, LOW);
    delay(20); // wait for 20 milliseconds
    servoDelay -= 20;
    //Serial.println(pulsewidth);
  while(servoDelay >=0);
//Movimiento de las fins
float moveSwing(float initPos)
  float finalPos;
  if(initMode == 0) //Sumar
    finalPos = initPos + posStep;
    finalPos = initPos - posStep;
  if(finalPos >= servo_MAX_POS) initMode = 1;
  else if(finalPos <= servo_MIN_POS) initMode = 0;
  return finalPos;
//Convertir ms en HH:MM
void convertToHours(unsigned long timeRemainingInMs)
  horas = ((timeRemainingInMs/1000L)/60L)/60L;
void convertToMin(unsigned long timeRemainingInMs)
  minutos = ((timeRemainingInMs/1000L)/60L) - horas*60L;
//Codigo
  //Serial.begin(9600);       //Iniciamos el serial (opcional)
  setPWMfreq();             //Definimos la frecuencuencia del PWM
  //ccs.begin();            //Iniciamos el CCS811 (opcional)
  IrReceiver.begin(irPin);  //Iniciamos el receptor IR
  hdc1080.begin(0x40);      //Iniciamos el HDC1080
  //hdc1080.setResolution(HDC1080_RESOLUTION_8BIT, HDC1080_RESOLUTION_8BIT);
  softServoAttach(servo_Pin);
  digitalWrite(tach, HIGH);
  //Definimos los pines
  pinMode(fan_control_pin, OUTPUT);
  pinMode(pinMosfet, OUTPUT);
  setPWMDuty(0);
  //Iniciamos OLED
  oled.begin(SSD1306_SWITCHCAPVCC, 0x3C);
  oled.setTextSize(tam);         //Tamano de letra
  oled.setFont(&FreeSans9pt7b);  //Fuente
  oled.setTextColor(SSD1306_WHITE);
  oled.clearDisplay();
  oled.display();
  //Forzamos primera medida de temp y hum
  tiempo7 = tempHum_updateInterval;
} //setup
  //Tomamos el tiempo actual
  currentMillis = millis();
  //Funcion para el control por mando IR
  if(IrReceiver.decode())
    //IrReceiver.printIRResultShort(&Serial);
    //Serial.println();
    if(IrReceiver.decodedIRData.flags == 0x01); //Do nothing, debouncing repeated signal within 100ms
    else if(IrReceiver.decodedIRData.protocol == UNKNOWN);
    else //Check functions
      //Serial.println();
      if(IrReceiver.decodedIRData.command == 0x1C) //Encendido - apagado
        powerState = !powerState;
        //start();
        switch(powerState)
          case 0: fanSpeed = 0;
                  setPWMDuty(fanSpeed); //Apagado
                  isSwing = 0;
                  isAuto = 0;
                  timerMode = 0;
                  servoPos = servo_CLOSED_POS;
                  moveServo(servoPos);
          case 1: fanSpeed = fan_START_SPEED;
                  setPWMDuty(fanSpeed); //Encendido
                  servoPos = servo_MED_POS;
                  //Serial.println(servoPos);
      else if(IrReceiver.decodedIRData.command == 0x18) //Subir fins
        if(powerState == 1) //Solo funciona si esta ON
          if((timerMode == 1)&&(timeChange == 1)) //Si modo temporizador
            setTime = setTime + (timerStepInterval * 60L * 1000L); //Sumamos 30 min al temporizador
            tiempo6 = currentMillis;
          else if(isSwing == 0) //Si no hay swing
            servoPos = servoPos + servo_CHANGE_POS;
            if(servoPos >= servo_MAX_POS)
              servoPos = servo_MAX_POS;
      else if(IrReceiver.decodedIRData.command == 0x52) //Bajar fins
            setTime = setTime - (timerStepInterval * 60L * 1000L); //Restamos 30 min al temporizador
            //Nos aseguramos de que no baje de 1 hora
            if(setTime <= 3600*1000L)
              setTime = 3600*1000L;
            servoPos = servoPos - servo_CHANGE_POS;
            if(servoPos <= servo_MIN_POS)
              servoPos = servo_MIN_POS;
      else if(IrReceiver.decodedIRData.command == 0x5A) //Subir velocidad ventilador
        fanSpeed = fanSpeed + fan_CHANGE_SPEED;
        if(powerState == 0)
          powerState = 1;
        if(fanSpeed >= 100)
          fanSpeed = 100;
        //Serial.print("FAN SPEED: ");
        //Serial.println(fanSpeed);
      else if(IrReceiver.decodedIRData.command == 0x8) //Bajar velocidad ventilador
        fanSpeed = fanSpeed - fan_CHANGE_SPEED;
        if(fanSpeed <= 0)
          fanSpeed = 0;
          setPWMDuty(fanSpeed); //Apagamos
          powerState = 0; //Marcamos que esta apagado
          isSwing = 0;    //Paramos el swing (si lo hay)
          moveServo(servoPos); //Cerramos las fins
      else if(IrReceiver.decodedIRData.command == 0x16) //FinSwing
          isSwing = !isSwing;
          //Decidimos si empezamos subiendo o bajando en funcion de la posicion inicial
          if(abs(servo_MIN_POS - servoPos) <= abs(servo_MAX_POS - servoPos))
            initMode = 0; //Empezamos sumando
            initMode = 1; //Restamos en otro caso
      else if(IrReceiver.decodedIRData.command == 0xD) //Screen ON-OFF
        isScreen = !isScreen;
        if(isScreen == 0)
          oled.display();
      else if(IrReceiver.decodedIRData.command == 0x45) //Modo auto
        isAuto = !isAuto;
        timerMode = 0; //Desactivamos el otro programa si esta activado
        if(isAuto == 0)
          powerState = 1;
          tiempo4 = -60000;
      else if(IrReceiver.decodedIRData.command == 0x46) //Modo timer
        timerMode = !timerMode;
        isAuto = 0; //Desactivamos el otro programa si esta activado
        if(timerMode == 1)
          setTime = 3600*1000L; //Partimos de 1 hora (en ms)
          timeChange = 1; //Permitimos el cambio de valores por un tiempo
    IrReceiver.resume(); //Enable receiving of the next value
  //Funcion para el movimiento de servo sin bloqueo
  if((isMovement == 1)&&((unsigned long)(currentMillis - tiempo) >= servoSpeed))
    tiempo = currentMillis;
  //Funcion del swingFin
  if((isSwing == 1)&&((unsigned long)(currentMillis - tiempo2) >= swingSpeed))
    tiempo2 = currentMillis;
    servoPos = moveSwing(servoPos);
  //Control de la informacion en pantalla
  if((isScreen == 1)&&((unsigned long)(currentMillis - tiempo3) >= 1000)) //1 Hz de refresco
    tiempo3 = currentMillis;
    //Serial.println(hdc1080.readTemperature());
    //Humedad
    oled.setCursor(84,20); //Movemos el cursor
    oled.print(hum,1);
    oled.drawBitmap(64,4,humLogo,20,25,WHITE);
    //Temperatura
    oled.setCursor(18,20);
    oled.print(temp,1);
    oled.drawBitmap(-2,2,tempLogo,20,25,WHITE);
    //TEST
    oled.setCursor(20,40);
    oled.print(currentMillis);
    //Power logo
    if((isAuto == 0)&&(powerState == 1)&&(timerMode == 0))
      oled.drawBitmap(25,42,powerLogo,78,32,WHITE);
      if(fanSpeed == 0)
        oled.fillRect(25,32,120,32,BLACK);
      else if(fanSpeed == 25)
        oled.fillRect(48,32,52,32,BLACK);
      else if(fanSpeed == 50)
        oled.fillRect(63,32,52,32,BLACK);
      else if(fanSpeed == 75)
        oled.fillRect(83,32,20,32,BLACK);
    else if((isAuto == 1)&&(powerState == 1)) //Marcador modo auto (control por temperatura)
      oled.setCursor(5,59);
      oled.print(F("A"));
      oled.drawRect(2,45,18,17,WHITE);
      oled.setCursor(35,59);
      oled.print(fanSpeed);
      oled.setCursor(64,59);
      oled.print(F("%"));
    else if((timerMode == 1)&&(powerState == 1)) //Modo timer (temporizador)
      //Llamamos a la funcion para convetir setTime en HH:MM
      convertToHours(setTime);
      convertToMin(setTime);
      oled.setCursor(34,59); //Mostramos el tiempo restante en pantalla
      oled.print(horas);
      oled.setCursor(45,59);
      oled.print(F("h:"));
      oled.setCursor(59,59);
      oled.print(minutos);
      oled.setCursor(80,59);
      oled.print(F("m"));
      //Marcador
      oled.print(F("T"));
    //Swing logo
    if(isSwing == 1)
      oled.setCursor(110,59);
      oled.print(F("S"));
      oled.drawRect(107,45,18,17,WHITE);
    oled.display();
  //Modo auto
  if((isAuto == 1)&&((unsigned long)(currentMillis - tiempo4) >= 60000)) //Refresh RPM cada 1 min
    tiempo4 = currentMillis;
    //Curva de temperatura-velocidad
    if(temp < TEMP_CUTOFF)
      isAuto = 0;                   //Apagamos el modo auto
      powerState = 0;               //Marcamos como apagado
      fanSpeed = 0;
      setPWMDuty(fanSpeed);         //Apagamos el ventilador
      if(temp > TEMP_MAX_SPEED) temp = TEMP_MAX_SPEED;
      fanSpeed = map(temp, TEMP_CUTOFF, TEMP_MAX_SPEED, 20, 100);
  //Temporizador
  if((timerMode == 1)&&((unsigned long)(currentMillis - tiempo5) >= 60000)) //Cada minuto restamos 1 minuto
    tiempo5 = currentMillis;
    setTime = setTime - 60000; //Ya que setTime trabaja en ms
    if(setTime <= 0)
      fanSpeed = 0;
      isSwing = 0;
      isAuto = 0;
      timerMode = 0;
      powerState = 0;
  //Timer set timeout
  if((timeChange == 1)&&((unsigned long)(currentMillis - tiempo6) >= 5000)) //Tras 5 segundos no nos dejara cambiar el tiempo y podemos mover las fins
    timeChange = 0;
  //Medida temperatura y humedad (Por separado para poder controlar la frecuencia de actualizacion)
  if((unsigned long)(currentMillis - tiempo7) >= tempHum_updateInterval)
    tiempo7 = currentMillis;
    temp = hdc1080.readTemperature();
    hum = hdc1080.readHumidity();
} //loop
I had to tinker with timers so that everyting worked together with just the 3 timers the nano has, that's why I'm not using the servo library.
This is what I have tried so far without luck:
  • Removing the HDC1080
  • Made everything with millis() rollover proof
  • Checked the ram usage with freeRam(), it stays at around 320 bytes
  • Tried to reduce even more ram usage
  • As I am powering the system with a 12v power supply and a buck converter for the arduino, tried changing the PSU just in case it's a noise issue
I am a bit lost now. This is the IDE output:
Sketch uses 23330 bytes (75%) of program storage space. Maximum is 30720 bytes.
Global variables use 688 bytes (33%) of dynamic memory, leaving 1360 bytes for local variables. Maximum is 2048 bytes.
Also, this is the schematic:
It appears you are getting noise from the fan motor. Try powering through Vin with the 12V, the additional filtering should help a lot.
I will try when I get home. This makes sense as I believe the system only crashes for med/high duty cycle. I will update as soon as I try it
I have been testing and the system also crashes when the fan is completely off. But it is also true that it crashes faster for higher rpm.
It is strange as I have used this nano-pwm fan setup before with the same step down with no issue, the difference was that I used a dht22 sensor instead of a HDC1080.
Maybe that's relevant, what do you think might be causing this instead of EM noise? May it be that I set the step down to 5.05V instead of 5.00V? I don't think that might cause issues but at this point I don't know what else to try
It appears you are using the Arduino 5V power supply to power the servo, which is a bad idea. Servos and other motors inject severe electrical noise into the power supply, which can cause Arduinos to malfunction or crash.
The best approach is to use separate power supplies (separate buck converters from 12V is fine). Make sure that the buck converter can easily handle the start/stall current for the servo (about 1 Ampere for the SG-90), and don't forget to connect the grounds.
When using buck converters you should verify that the ground pasess through, on some they control the ground not the positive rail. I am more convinced it is EMI noise especially if the power for the fan is going through the Arduino board in any way.
Yes, they're sharing the power but during my testing the servo is not being used. As I am not using the servo library, it is not holding position as it would in normal conditions, so servo nose should not be an issue for now.
The buck converter should be more than capable to power both servo and arduino, it's the common one from Aliexpress.
All the connections you see above are in a PCB, maybe that intensifies the noise due to the paths being close to each other.
This is the buck converther I am using: This one
Maybe I don't understand what you mean, the power of the fan comes directly from the power supply through the mosfet. The arduino controls the mosfet (used to completely power off the fan as it does not support 0 rpm) it also sends the pwm signal and reads the tachometer.
I have everything set up in a PCB, if it is EM noise may it be solved adding a capacitor somewhere?
Thanks
You could be introducing the noise via the ground and or + bus on your card as your schematic indicates the FAN current is through the board. Connect the +12 external to the board and see what happens. Also I would recommend a 100 Ohm resistor in the gate lead and the pull down connected to the port and changed to about 10K. The internet showes this immage which passes the ground through.
image so that should be OK. Also you do not indicate the part number of the MOSFET so if it is not avalanche rated it could be part of your problem as the flyback from the motor could add a lot of noise to the board.
The MOSFET I am using is an IRFZ44N.
I have been testing this month and I have realised that the nano only crashes if the screen is on for some time (random). If I just turn it on to see some info and keep it of the rest of the time it works perfectly.
Any idea why is that? May it still be caused by the electrical noise? I have no idea what is happening, it's just so strange as I have used the same setup in a smaller but still similar project and had no issues.
Long wires are antennas, both transmitter and receiving. Try using twisted wires for the fan and power supplies. Does it run without a problem if the fan is not connected?
