Arduino Nano, Digital Pots, and Interfacing with Other Circuits
Hi, just started getting into Arduino, but ran into an issue with my first project. The project uses an Arduino Nano, MCP41100 100k Digital Pots, and a Guitar Pedal Circuit whose original pots function as a voltage divider (3.3v). There is also another pot that processes audio volume.
My issue is is that my arduino display (Adafruit LCD) goes bonkers whenever I try and interface my digipots with the guitar pedal circuits pot pads.
I noticed that it does not work when I try to connect the digipots A, W, B pins to the guitar pedal circuits' potentiometer pads whose function is a voltage divider (3.3v).
When I disconnect the guitar pedal circuit pads that divide the 3.3v and only connect the volume audio pads, my display works fine.
Am I right to assume that the Arduino Nano runs at 5v and is running into trouble with the 3.3v coming from the guitar pedal's pots pads?
No, the problem is something else.
3.3v on 5v arduino is fine.
Thanks for the confirmation! I put a different 9v to 5v regulator circuit in there and that seems to have fixed it!
