Arduino: 1.8.15 (Windows 10), Board: "Arduino Nano, ATmega328P"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\ASUS\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=0000_0000 -ide-version=10815 -build-path C:\Users\ASUS\AppData\Local\Temp\arduino_build_151630 -warnings=none -build-cache C:\Users\ASUS\AppData\Local\Temp\arduino_cache_635320 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\ASUS\Desktop\sketch_jun04a\sketch_jun04a\sketch_jun04a\sketch_jun04a\sketch_jun04a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\ASUS\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=0000_0000 -ide-version=10815 -build-path C:\Users\ASUS\AppData\Local\Temp\arduino_build_151630 -warnings=none -build-cache C:\Users\ASUS\AppData\Local\Temp\arduino_cache_635320 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\ASUS\Desktop\sketch_jun04a\sketch_jun04a\sketch_jun04a\sketch_jun04a\sketch_jun04a.ino
Using board 'nano' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\ASUS\AppData\Local\Temp\arduino_build_151630\sketch\sketch_jun04a.ino.cpp" -o nul
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\ASUS\AppData\Local\Temp\arduino_build_151630\sketch\sketch_jun04a.ino.cpp" -o "C:\Users\ASUS\AppData\Local\Temp\arduino_build_151630\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\ASUS\AppData\Local\Temp\arduino_build_151630\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\ASUS\AppData\Local\Temp\arduino_build_151630\sketch\sketch_jun04a.ino.cpp" -o "C:\Users\ASUS\AppData\Local\Temp\arduino_build_151630\sketch\sketch_jun04a.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\ASUS\AppData\Local\Temp\arduino_cache_635320\core\core_arduino_avr_nano_cpu_atmega328_0c812875ac70eb4a9b385d8fb077f54c.a
Linking everything together...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\ASUS\AppData\Local\Temp\arduino_build_151630/sketch_jun04a.ino.elf" "C:\Users\ASUS\AppData\Local\Temp\arduino_build_151630\sketch\sketch_jun04a.ino.cpp.o" "C:\Users\ASUS\AppData\Local\Temp\arduino_build_151630/..\arduino_cache_635320\core\core_arduino_avr_nano_cpu_atmega328_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\Users\ASUS\AppData\Local\Temp\arduino_build_151630" -lm
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\ASUS\AppData\Local\Temp\arduino_build_151630/sketch_jun04a.ino.elf" "C:\Users\ASUS\AppData\Local\Temp\arduino_build_151630/sketch_jun04a.ino.eep"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\ASUS\AppData\Local\Temp\arduino_build_151630/sketch_jun04a.ino.elf" "C:\Users\ASUS\AppData\Local\Temp\arduino_build_151630/sketch_jun04a.ino.hex"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-size" -A "C:\Users\ASUS\AppData\Local\Temp\arduino_build_151630/sketch_jun04a.ino.elf"
Sketch uses 2992 bytes (9%) of program storage space. Maximum is 30720 bytes.
Global variables use 200 bytes (9%) of dynamic memory, leaving 1848 bytes for local variables. Maximum is 2048 bytes.
An error occurred while uploading the sketch
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\ASUS\AppData\Local\Temp\arduino_build_151630/sketch_jun04a.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
