Arduino Nano ESP32 Analog Input
Hello there!
From what I was reading in the website about Arduino Nano ESP32, the voltage allowed through the pins has to be 3.3V or bellow. This means I cannot put, imagine, 4.4V through an Analog Pin right?
Thanks for the help,
João Duarte
Correct.
Voltage divider - Wikipedia
That right. to read the signal, you will have to reduce it. You can use an operational amplifier for example.
That would fry it. There is a thing as noted by runaway_pancake called a voltage divider. I am assuming your calculator is in the other room so this link should do it for you. Voltage Divider Calculator You will probably use a 10K and a 5.1K resistor. Use the calculator and determine what is best for you. I have found that the A/D works best by keeping the A/D input impedance at 10K.
