I have an Arduino Nano ESP32 connected with an Arduino USB Type-C® Cable 2-in1 to an Apple Macbook M1pro (macOS Sonoma version 14.4.1) that runs the Arduino IDE version 2.3.2.
I've installed the Arduino ESP32 Boards Manager via the IDE. Then I tried to run an example sketch "WifiScan" to check if everything works properly, but when I upload the code, it compiles the sketch, but then it says the following in the Serial Monitor:
Opening DFU capable USB device...
Device ID 2341:0070
Device DFU version 0101
Claiming USB DFU Interface...
Setting Alternate Interface #0 ...
Determining device status...
DFU state(2) = dfuIDLE, status(0) = No error condition is present
DFU mode device DFU version 0101
Device returned transfer size 4096
Copying data from PC to DFU device
Download [ ] 0% 0 bytes
Download [= ] 4% 28672 bytes
Download [== ] 8% 57344 bytes
Download [======================== ] 96% 659456 bytes
Download [=========================] 100% 681056 bytes
Download done.
DFU state(7) = dfuMANIFEST, status(0) = No error condition is present
Done!
But it doesn't show me the available wifi networks. I tried uploading a "Blink" sketch, which worked, so the board is connected to the port, altough it doesn't say COM, but rather Port: /dev/cu.usbmodemECDA3B5532142 (Arduino Nano ESP32) and i still get the same message as described above in the serial monitor.
Does anybody know how I can fix this?
