arduino nano esp8266 serial problems
have a problem with my arduino nano Atmega328 and my esp8266 01 module. I have connected the esp8266 on my arduino board with out ftdi.
I have made the following connection: I an using a 5V Arduino Nano which of course is 5V. The Esp8266 is a 3.3v device and so I am using a voltage divider to bring the Arduinos 5V down to 3.3v. If you are using a 3.3v Arduino then you do not need the voltage divider.
The wiring is very similar to the FTDI. Arduino pin 3 to voltage divider and then to ESP8266 RX Arduino pin 2 to ESP8266 TX Arduino GND to ESP8266 GND Pull CH_PD HIGH with a 10K resistor to +3.3v +3.3V to vcc
You only need the voltage divider on the Arduino TX pin. The 5V Arduino will read 3.3v as HIGH so you can connect the ESP8266 TX pin directly to the Arduino RX pin.
The problem i had and i cant handle is that when i start up the Arduino tx,rx leds works continuously so i cant have access to my serial monitor of Arduino Ide. Also i see that esp8266 blue led works also as i see it blinking so it shows that it trys to send/ receive. So with that problem i cant send or receive any command to the IDE serial. Also when i try to upload my program on Arduino i must have disconnected the esp. If i don t i can t upload it.
Any ideas guys? I would be gratefull
**I also try to implement code with AltSoftSerial but i have libraries issues my laptop doesnot recognize it. ( i download it and i put it in the same folder with my code ) ** I ve also linked a picture with my circuit schematic .
*** This is my code
#include <SoftwareSerial.h>
SoftwareSerial ESPserial(2, 3); // RX | TX
{ Serial.begin(9600); // communication with the host computer
// Start the software serial for communication with the ESP8266
ESPserial.begin(9600);
Serial.println("");
Serial.println("Remember to to set Both NL & CR in the serial monitor.");
Serial.println("Ready");
Serial.println("");}
// listen for communication from the ESP8266 and then write it to the serial monitor
if ( ESPserial.available() ) { Serial.write( ESPserial.read();} / / listen for user input and send it to the ESP8266
if ( Serial.available() ) { ESPserial.write( Serial.read() ); }}
I suggest you to use an external power source for esp, try to change your baudrate and do not connect TX or RX to voltage divider you can directly connect them to arduino
