Hi everyone,
I'm currently using the Arduino nano every in my application to :
-Communicate with the BMS equipped with a BQ2060 with SMBUS (already done)
-Confirm the presence of an NTC (that is on the BMS of my battery) with a voltage divider bridge.
My voltage divider bridge is supposed to give me a Vout around 2.5V (NTC = 10K and the other resistor is 10Kohms too)
The issue is that with the simple code that i have :
I've just test the same thing on an arduino Uno and it's working well, the same wiring, same sketch, all the same system, so i guess it's not my wiring or something and it's linked with the nano every.
(I highlighted in red on the first picture so it's easier for you to understand)
Not sure this is relevant , but by default the analog input uses the chip supply voltage as its reference - so if that changes , your reading may differ.
The power supply arrangements on the Every may differ to those on a UNO .
Some research needed
