I'm trying to use analogwrite to generate PWM signal on pins 3, 6, 9, and 10, but I want it to be at 50Hz. I've managed to get it down to 60ish Hz with a prescaler on Timer0. I thoughts changing the period registry would allow me to get the rest of the way there, but that doesn't seem to effect the analogwrite period. I'd like to be able to independently control the duty cycle for each of the pins, but the frequency should always be 50Hz. I've read through the datasheet but I can't figure out why changing the period of the clock wouldn't effect the analogwrite function. Thanks for any help you can give me!
#define PIN 3
#define OFF 14 // 0 to 255
#define IDLE 15 // 0 to 255
#define PWM_1100 17 // 0 to 255
#define PWM_TIMER_PERIOD 100 // For frequency
TCA0.SINGLE.CTRLA &= ~TCA_SINGLE_ENABLE_bm; // Turn off timer while we change parameters.
TCA0.SINGLE.CTRLA &= ~TCA_SINGLE_CLKSEL_gm; // Clear all CLKSEL bits.
TCA0.SINGLE.CTRLA |= 0b1110; // prescaler
TCA0.SINGLE.CMP0 = PWM_TIMER_PERIOD;
TCA0.SINGLE.CTRLA |= TCA_SINGLE_ENABLE_bm; // Re-enable timer.
pinMode(PIN, OUTPUT);
analogWrite(PIN, OFF);
