I have a pcb made for using the sim800l and arduino nano every.
I tried using delays for the arduino to start communicating with the sim module because it would not work otherwise. I found out that i need to wait/reset the arduino in order for it to work.
Because the pcb was already made i added a 10 second delay.
When i turn it on, most times it does not work.
I tried to use the watchdog with the Adafruit Watchdog library but the example code would not compile for the Arduino Nano Every.
The delay() function does not wait the set amount of time. If i set it to 5 seconds for example, it sometimes waits 3 seconds sometimes 6 sometimes 4.
The bigger the value the more variation there is.
How can i make this work?
Is there a better way of doing this?
Here is the code:
#include <SoftwareSerial.h>
#include <avr/wdt.h>
SoftwareSerial sim(10, 11);
String broj1 = "MY NUMBER GOES HERE";
String fault = "Imam greska Vlez 1";
String pozar = "Ima pozar Vlez 1";
String fault2 = "Imam greska Vlez 2";
String pozar2 = "Ima pozar Vlez 2";
String faultkraj = "Vo red sum. Vlez 1 ";
String pozarkraj = "Nema pozar Vlez 1";
String faultkraj2 = "Vo red sum. Vlez 2 ";
String pozarkraj2 = "Nema pozar Vlez 2";
bool imasignal3 = 0;
bool imasignal4 = 0;
bool imasignal5 = 0;
bool imasignal6 = 0;
bool simstart = false;
unsigned long time_now = 0;
for (int i = 3; i <= 6; i++)
pinMode(i, INPUT);
time_now = millis();
while (millis() < time_now + 10000) {
delay(1);
Serial.println("Zapocnata programa.");
if (simstart == false ) {
sim.begin(9600);
delay(100);
sim.print("AT");
delay(100);
simstart = true;
//DOBIEN SIGNAL
if (digitalRead(3) == 1) {
izvestifault(1, broj1);
if (digitalRead(4) == 1) {
izvestifault(2, broj1);
if (digitalRead(5) == 1) {
izvestipozar(1, broj1);
if (digitalRead(6) == 1 ) {
izvestipozar(2, broj1);
//KRAJ NA SIGNAL
if (digitalRead(3) == 0) {
izvestifaultkraj(1, broj1);
if (digitalRead(4) == 0) {
izvestifaultkraj(2, broj1);
if (digitalRead(5) == 0) {
imasignal5 = 0;
if (digitalRead(6) == 0) {
imasignal6 = 0;
void izvestifault(int vlez, String broj)
if (vlez == 1) {
if (imasignal3 == 0 ) {
sim.print("AT");
delay(200);
Serial.println("Registriran signal za Fault, Vlez 1");
Serial.println("Pocnuva dojavuvanje za Fault, Vlez 1");
Serial.print("Pocnato prakjanje poraka na broj ");
Serial.print(broj);
Serial.println(" za Fault, Vlez 1");
poraka(broj, fault);
Serial.print("Zavrseno prakjanje poraka na broj ");
Serial.print(broj);
Serial.println("Zavrseno dojavuvanje za Fault, Vlez 1");
imasignal3 = 1;
else if (vlez == 2) {
if (imasignal4 == 0 ) {
sim.print("AT");
delay(200);
Serial.println("Registriran signal za Fault, Vlez 2");
Serial.println("Pocnuva dojavuvanje za Fault, Vlez 2");
Serial.print(broj);
Serial.println(" za Fault, Vlez 2");
poraka(broj, fault2);
Serial.print(broj);
Serial.println("Zavrseno dojavuvanje za Fault, Vlez 2");
imasignal4 = 1;
void izvestipozar(int vlez, String broj)
if (vlez == 1) {
if (imasignal5 == 0 ) {
sim.print("AT");
delay(200);
Serial.println("Registriran signal za Pozar, Vlez 1");
Serial.println("Pocnuva dojavuvanje za Pozar, Vlez 1");
Serial.print("Pocnato prakjanje povik na broj ");
Serial.print(broj);
Serial.println(" za Pozar, Vlez 1");
povik(broj);
Serial.print("Zavrseno prakjanje povik na broj ");
Serial.print(broj);
Serial.println("Zavrseno dojavuvanje za Pozar, Vlez 1");
imasignal5 = 1;
if (imasignal6 == 0 ) {
sim.print("AT");
delay(200);
Serial.println("Registriran signal za Pozar, Vlez 2");
Serial.println("Pocnuva dojavuvanje za Pozar, Vlez 2");
Serial.print(broj);
Serial.println(" za Pozar, Vlez 2");
povik(broj);
Serial.print(broj);
Serial.println("Zavrseno dojavuvanje za Pozar, Vlez 2");
imasignal6 = 1;
void izvestifaultkraj(int vlez, String broj)
if (vlez == 1) {
if (imasignal3 == 1 ) {
sim.print("AT");
delay(200);
Serial.print("Izguben signal za Fault, Vlez 1");
Serial.println("Pocnuva dojavuvanje za kraj na Fault, Vlez 1");
Serial.print(broj);
Serial.println(" za kraj na Fault, Vlez 1");
poraka(broj, faultkraj);
Serial.print(broj);
Serial.println("Zavrseno dojavuvanje za kraj na Fault, Vlez 1");
imasignal3 = 0;
if (imasignal4 == 1 ) {
sim.print("AT");
delay(200);
Serial.print("Izguben signal za Fault, Vlez 2");
Serial.println("Pocnuva dojavuvanje za kraj na Fault, Vlez 2");
Serial.print(broj);
Serial.println(" za kraj na Fault, Vlez 2");
poraka(broj, faultkraj2);
Serial.print(broj);
Serial.println("Zavrseno dojavuvanje za kraj na Fault, Vlez 2");
imasignal4 = 0;
void izvestipozarkraj(int vlez, String broj)
if (vlez == 1) {
if (imasignal5 == 1 ) {
sim.print("AT");
delay(100);
Serial.print("Izguben signal za Pozar, Vlez 1");
Serial.println("Pocnuva dojavuvanje za kraj na Pozar, Vlez 1");
Serial.print(broj);
Serial.println(" za kraj na Pozar, Vlez 1");
povik(broj);
Serial.print(broj);
Serial.println("Zavrseno dojavuvanje za kraj na Pozar, Vlez 1");
imasignal5 = 0;
if (imasignal6 == 1 ) {
sim.print("AT");
delay(100);
Serial.print("Izguben signal za Pozar, Vlez 2");
Serial.println("Pocnuva dojavuvanje za kraj na Pozar, Vlez 2");
Serial.print(broj);
Serial.println(" za kraj na Pozar, Vlez 2");
povik(broj);
Serial.print(broj);
Serial.println("Zavrseno dojavuvanje za kraj na Pozar, Vlez 2");
imasignal6 = 0;
void povik(String broj)
sim.print("AT");
delay(100);
sim.print(F("ATD"));
sim.print(broj);
sim.print(F(";\r\n"));
void poraka(String broj, String tekst) {
sim.print("AT+CMGF=1");
delay(200);
sim.print("AT+CMGS=\"" + broj + "\"\r");
sim.print(tekst);
delay(200);
sim.print((char)26);
The code is certainly not the best but it should work.
Also: The antenna should not be a problem because i stretched the one that came with it from (maybe)2cm to 6-7cm.
I am using an authentic arduino nano every.
The if(simstart == false) statement is there because it worked worse when the sim.begin() function was in the setup.(after the delays of course)
