Arduino Nano Every bricked/fried? // USB + External Power
It finally happened: I burned an Arduino :frowning:
Main story: I connected a 12V DC supply to the Every's Vin and GND pins. The board was brand new and had the default blink sketch preloaded; the D13 LED was blinking as usual. Then, I connected the arduino with a known working USB cable to my computer. At this point I stopped paying attention to the board itself as I never thought there could be a problem. I have connected arduino Due with the exact same power supply and USB simultaneously without trouble.
After a while I tried to upload a sketch and got this upload error and output (Arduino IDE 1.8.12).
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\Rick\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM10
         Using Programmer              : jtag2updi
         Overriding Baud Rate          : 115200
JTAG ICE mkII sign-on message:
Communications protocol version: 1
M_MCU:
  boot-loader FW version:        1
  firmware version:              6.00
  hardware version:              1
S_MCU:
  hardware version:              1
Serial number:                   00:00:00:00:00:00
Device ID:                       JTAGICE mkII
         AVR Part                      : ATmega4809
         Chip Erase delay              : 0 us
         PAGEL                         : P00
         BS2                           : P00
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 0
         StabDelay                     : 0
         CmdexeDelay                   : 0
         SyncLoops                     : 0
         ByteDelay                     : 0
         PollIndex                     : 0
         PollValue                     : 0x00
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           prodsig        0     0     0    0 no         61   61      0     0     0 0x00 0x00
           fuses          0     0     0    0 no          9    0      0     0     0 0x00 0x00
           fuse0          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse1          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse2          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse4          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse5          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse6          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse7          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse8          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0     0     0 0x00 0x00
           data           0     0     0    0 no          0    0      0     0     0 0x00 0x00
           usersig        0     0     0    0 no         64   64      0     0     0 0x00 0x00
           flash          0     0     0    0 no      49152  128      0     0     0 0x00 0x00
           eeprom         0     0     0    0 no        256   64      0     0     0 0x00 0x00
         Programmer Type : JTAGMKII_PDI
         Description     : JTAGv2 to UPDI bridge
         M_MCU hardware version: 1
         M_MCU firmware version: 6.00
         S_MCU hardware version: 1
         S_MCU firmware version: 6.00
         Vtarget         : 5.0 V
avrdude: jtagmkII_initialize(): Cannot locate "flash" and "boot" memories in description
avrdude: jtagmkII_reset(): timeout/error communicating with programmer (status -1)
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude: jtagmkII_close(): timeout/error communicating with programmer (status -1)
avrdude done.  Thank you.
the selected serial port
 does not exist or your board is not connected
I turned to look at the board again and the D13 LED wasn't blinking anymore and I can't upload any sketches. Unfortunately I don't know when exactly the LED stopped blinking, and therefore the main chip had stopped responding.
The Every is recognized normally by the computer, the POWER LED is on, and the onboard voltage regulator still provides the 5V and 3.3V pins with the correct voltages so I am assuming it is ok. There are no visibly burnt or destructed components and there was no smoke.
I am assuming the 4809 chip is fried because I can't upload to it. Could that be because I connected both USB + External Power supply? Maybe it was just bricked? And, anyway, is there any way to fix the board?
Irrelevant sidestory: Before even connecting the board to USB I connected D10 of the Nano Every to a darlington pair's base without a resistor. Measuring with a multimeter and an older arduino nano, I found that the base only absorbs 1.4 mA without a resistor when D10 goes HIGH. Therefore, that can't be the reason my Arduino nano every fried. And the preloaded sketch didn't even use D10.
Try a bare-bones test ... just the Nano Every with only the USB cable connected to the PC.
Check the Boards Manager ...
In the Tools options, check Board, Port and Programmer settings ...
Check this thread.
Now try uploading the Blink sketch ...
yes, unfortunately still nothing.
Could have blown D2, which isolates VUSB from the 5V line.
See upper left of the Every schematic.
I will see into that, thanks.
In case the microcontroller is the one fried, there is a small shop here that can substitute the onboard atmega4809 with a new one. Could this make the board work again or do I need a special procedure to burn some bootloader the first time or anything?
