Arduino Nano Every ModBus RFM69HCW Kommunikation
Hallo zusammen
Ich möchte per Funk zwei Adriano Nano Every miteinander kommunizieren lassen. Dafür habe ich zwei RFM69HCW Module.
Angeschlossen habe ich beide Module wie folgt:
Nano Every ---- RFm69HCW
2 DI00
10 NSS
11 MOSI
12 MISO
13 SCK
3.3V 3.3V
GND GND
Ich verwende folgende Bibliothek GitHub - LowPowerLab/RFM69: RFM69 library for RFM69W, RFM69HW, RFM69CW, RFM69HCW (semtech SX1231, SX1231H)
Ich schaffe es nicht diese beiden Module miteinander zu Kommunizieren. Hat einer eine Idee woran dies liegen kann?
Danke im Voraus
// RFM69HCW Example Sketch
// Send serial input characters from one RFM69 node to another
// Based on RFM69 library sample code by Felix Rusu
// http://LowPowerLab.com/contact
// Modified for RFM69HCW by Mike Grusin, 4/16
// This sketch will show you the basics of using an
// RFM69HCW radio module. SparkFun's part numbers are:
// 915MHz: https://www.sparkfun.com/products/12775
// 434MHz: https://www.sparkfun.com/products/12823
// See the hook-up guide for wiring instructions:
// https://learn.sparkfun.com/tutorials/rfm69hcw-hookup-guide
// Uses the RFM69 library by Felix Rusu, LowPowerLab.com
// Original library: https://www.github.com/lowpowerlab/rfm69
// SparkFun repository: https://github.com/sparkfun/RFM69HCW_Breakout
// Include the RFM69 and SPI libraries:
#include <RFM69.h>
#include <SPI.h>
// Addresses for this node. CHANGE THESE FOR EACH NODE!
#define NETWORKID     0   // Must be the same for all nodes
#define MYNODEID      1   // My node ID
#define TONODEID      2   // Destination node ID
// RFM69 frequency, uncomment the frequency of your module:
#define FREQUENCY   RF69_433MHZ
//#define FREQUENCY     RF69_915MHZ
// AES encryption (or not):
#define ENCRYPT       true // Set to "true" to use encryption
#define ENCRYPTKEY    "TOPSECRETPASSWRD" // Use the same 16-byte key on all nodes
// Use ACKnowledge when sending messages (or not):
#define USEACK        true // Request ACKs or not
// Packet sent/received indicator LED (optional):
#define LED           9 // LED positive pin
#define GND           8 // LED ground pin
// Create a library object for our RFM69HCW module:
RFM69 radio;
  // Open a serial port so we can send keystrokes to the module:
  Serial.print("Node ");
  Serial.print(MYNODEID,DEC);
  Serial.println(" ready");
  // Set up the indicator LED (optional):
  pinMode(LED,OUTPUT);
  digitalWrite(LED,LOW);
  pinMode(GND,OUTPUT);
  digitalWrite(GND,LOW);
  // Initialize the RFM69HCW:
  // radio.setCS(10);  //uncomment this if using Pro Micro
  radio.initialize(FREQUENCY, MYNODEID, NETWORKID);
  radio.setHighPower(); // Always use this for RFM69HCW
  // Turn on encryption if desired:
  if (ENCRYPT)
    radio.encrypt(ENCRYPTKEY);
  // Set up a "buffer" for characters that we'll send:
  static char sendbuffer[62];
  static int sendlength = 0;
  // SENDING
  // In this section, we'll gather serial characters and
  // send them to the other node if we (1) get a carriage return,
  // or (2) the buffer is full (61 characters).
  // If there is any serial input, add it to the buffer:
  if (Serial.available() > 0)
    char input = Serial.read();
    if (input != '\r') // not a carriage return
      sendbuffer[sendlength] = input;
      sendlength++;
    // If the input is a carriage return, or the buffer is full:
    if ((input == '\r') || (sendlength == 61)) // CR or buffer full
      // Send the packet!
      Serial.print("sending to node ");
      Serial.print(TONODEID, DEC);
      Serial.print(", message [");
      for (byte i = 0; i < sendlength; i++)
        Serial.print(sendbuffer[i]);
      Serial.println("]");
      // There are two ways to send packets. If you want
      // acknowledgements, use sendWithRetry():
      if (USEACK)
        if (radio.sendWithRetry(TONODEID, sendbuffer, sendlength))
          Serial.println("ACK received!");
          Serial.println("no ACK received");
      // If you don't need acknowledgements, just use send():
      else // don't use ACK
        radio.send(TONODEID, sendbuffer, sendlength);
      sendlength = 0; // reset the packet
      Blink(LED,10);
  // RECEIVING
  // In this section, we'll check with the RFM69HCW to see
  // if it has received any packets:
  if (radio.receiveDone()) // Got one!
    // Print out the information:
    Serial.print("received from node ");
    Serial.print(radio.SENDERID, DEC);
    // The actual message is contained in the DATA array,
    // and is DATALEN bytes in size:
    for (byte i = 0; i < radio.DATALEN; i++)
      Serial.print((char)radio.DATA[i]);
    // RSSI is the "Receive Signal Strength Indicator",
    // smaller numbers mean higher power.
    Serial.print("], RSSI ");
    Serial.println(radio.RSSI);
    // Send an ACK if requested.
    // (You don't need this code if you're not using ACKs.)
    if (radio.ACKRequested())
      radio.sendACK();
      Serial.println("ACK sent");
    Blink(LED,10);
void Blink(byte PIN, int DELAY_MS)
// Blink an LED for a given number of ms
  digitalWrite(PIN,HIGH);
  delay(DELAY_MS);
  digitalWrite(PIN,LOW);
Sind die RFM69HCW in Europa/Deutschland überhaupt zugelassen?
Grüße Uwe
Ja die sind zugelassen sie Kommunizieren über eine freie Frequenz.
Hier noch der Code für den Empfänger
#include <RFM69.h>
#include <SPI.h>
#define MYNODEID      2   // My node ID
#define TONODEID      1   // Destination node ID
RFM69 radio;
  if (ENCRYPT)
  // SENDING
      sendlength++;
      // Send the packet!
      if (USEACK)
      Blink(LED,10);
  // RECEIVING
      radio.sendACK();
    Blink(LED,10);
  delay(DELAY_MS);
Sind eigentlich nicht zugelassen. 433 MHz ist zugelassen, aber nicht mit 100mW!
Laut Bundesnetzagentur maximal 10mW!
https://www.bundesnetzagentur.de/SharedDocs/Downloads/DE/Sachgebiete/Telekommunikation/Unternehmen_Institutionen/Frequenzen/20191202_Frequenzplan.pdf;jsessionid=A1D8D5B43EA92372A13EC65E9C77FC17?__blob=publicationFile&v=2
Seite 279 oben
Seite 279 mitte ist Betriebsfunk, trifft aber in dem Anwendungsfall nicht zu!
Gruß, Jürgen
