Arduino Nano Every no serial Transmission
Hi There,
I am trying to turn a Nano Every into a MIDI controller. Until now I developed on an Arduino Uno and got everything running.
With the Nano Every however, there seems to be no transmission through the serial port.
I made a quick sketch to focus on sending data through the serial Pin.
Serial.write(181); //MIDICC
Serial.write(32); //CC32 Bank Change
Serial.write(0);
Serial.write(197); //MIDIPC
Serial.write(15);
delay(2000);
If I monitor through Hairless MIDI there are no bytes being sent. As soon as I open the serial monitor in the Arduino IDE serial data is being sent. Now when i check back in Hairless MIDI the data is sent.
How do I get it to send the data out from the start (as it does with the UNO)?
Taster_Test.ino (241 Bytes)
I always thought Midi transmitted at 31250 baud and not 9600 baud.
Nano Every has two serial ports:
Serial - USB only
Serial1 - Tx-Rx (D1-D0)
Try changing Serial by Serial1 in your sketch.
