Arduino Nano Every not uploading
Hi
can see nano every on com port 2 ok
Arduino Nano Every looking for avrdude.conf when trying to upload a sketch
i copied an avrdude.conf from gemma directory.
but now says it cant find programmer id "jtag2updi" and shows all the valid programmers
does anyone know the fix please?
You have to find and use Nano Every - not simply Nano, a common mistake.
You should not need to modify the avrdude.conf file.
Have you installed the Arduino megaAVR boards package in the IDE and selected the correct board?
re installed latest Arduino
yes, Selecting Nano Every all ok
yes, MegaAVR boards installled
it maybe a problem with avrdude.conf not installed correctly?
avrdude: Can't find programmer id "jtag2updi"
Valid programmers are:
2232HIO = FT2232H based generic programmer [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:403]
4232h = FT4232H based generic programmer [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:431]
89isp = Atmel at89isp cable [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1187]
abcmini = ABCmini Board, aka Dick Smith HOTCHIP [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1086]
alf = Nightshade ALF-PgmAVR, http://nightshade.homeip.net/ [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1046]
arduino = Arduino [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:351]
arduino-ft232r = Arduino: FT232R connected to ISP [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:679]
arduinogemma = Arduino Gemma. Based on USBtiny [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:752]
arduinoisp = [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:761]
atisp = AT-ISP V1.1 programming cable for AVR-SDK1 from http://micro-research.co.th/ [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1142]
avr109 = Atmel AppNote AVR109 Boot Loader [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:777]
avr910 = Atmel Low Cost Serial Programmer [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:636]
avr911 = Atmel AppNote AVR911 AVROSP [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:784]
avrftdi = FT2232D based generic programmer [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:377]
avrisp = Atmel AVR ISP [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:523]
avrisp2 = Atmel AVR ISP mkII [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:543]
avrispmkII = Atmel AVR ISP mkII [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:537]
avrispv2 = Atmel AVR ISP V2 [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:530]
bascom = Bascom SAMPLE programming cable [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1040]
blaster = Altera ByteBlaster [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1164]
bsd = Brian Dean's Programmer, http://www.bsdhome.com/avrdude/ [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:995]
buspirate = The Bus Pirate [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:548]
buspirate_bb = The Bus Pirate (bitbang interface, supports TPI) [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:555]
butterfly = Atmel Butterfly Development Board [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:770]
butterfly_mk = Mikrokopter.de Butterfly [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:798]
bwmega = BitWizard ftdi_atmega builtin programmer [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:666]
c2n232i = serial port banging, reset=dtr sck=!rts mosi=!txd miso=!cts [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1315]
dapa = Direct AVR Parallel Access cable [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1130]
dasa = serial port banging, reset=rts sck=dtr mosi=txd miso=cts [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1287]
dasa3 = serial port banging, reset=!dtr sck=rts mosi=txd miso=cts [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1301]
diecimila = alias for arduino-ft232r [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:690]
dragon_dw = Atmel AVR Dragon in debugWire mode [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:933]
dragon_hvsp = Atmel AVR Dragon in HVSP mode [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:924]
dragon_isp = Atmel AVR Dragon in ISP mode [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:906]
dragon_jtag = Atmel AVR Dragon in JTAG mode [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:897]
dragon_pdi = Atmel AVR Dragon in PDI mode [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:942]
dragon_pp = Atmel AVR Dragon in PP mode [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:915]
dt006 = Dontronics DT006 [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1030]
ere-isp-avr = ERE ISP-AVR http://www.ere.co.th/download/sch050713.pdf [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1153]
frank-stk200 = Frank STK200 [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1177]
ft232r = FT232R Synchronous BitBang [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:654]
ft245r = FT245R Synchronous BitBang [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:643]
futurlec = Futurlec.com programming cable. [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1097]
jtag1 = Atmel JTAG ICE (mkI) [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:811]
jtag1slow = Atmel JTAG ICE (mkI) [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:816]
jtag2 = Atmel JTAG ICE mkII [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:846]
jtag2avr32 = Atmel JTAG ICE mkII im AVR32 mode [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:879]
jtag2dw = Atmel JTAG ICE mkII in debugWire mode [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:861]
jtag2fast = Atmel JTAG ICE mkII [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:840]
jtag2isp = Atmel JTAG ICE mkII in ISP mode [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:852]
jtag2pdi = Atmel JTAG ICE mkII PDI mode [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:888]
jtag2slow = Atmel JTAG ICE mkII [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:835]
jtag3 = Atmel AVR JTAGICE3 in JTAG mode [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:950]
jtag3dw = Atmel AVR JTAGICE3 in debugWIRE mode [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:964]
jtag3isp = Atmel AVR JTAGICE3 in ISP mode [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:971]
jtag3pdi = Atmel AVR JTAGICE3 in PDI mode [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:957]
jtagkey = Amontec JTAGKey, JTAGKey-Tiny and JTAGKey2 [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:438]
jtagmkI = Atmel JTAG ICE (mkI) [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:803]
jtagmkII = Atmel JTAG ICE mkII [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:827]
jtagmkII_avr32 = Atmel JTAG ICE mkII im AVR32 mode [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:870]
lm3s811 = Luminary Micro LM3S811 Eval Board (Rev. A) [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:503]
mib510 = Crossbow MIB510 programming board [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:587]
mkbutterfly = Mikrokopter.de Butterfly [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:792]
nibobee = NIBObee [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:721]
o-link = O-Link, OpenJTAG from www.100ask.net [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:474]
openmoko = Openmoko debug board (v3) [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:485]
pavr = Jason Kyle's pAVR Serial Programmer [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:979]
pickit2 = MicroChip's PICkit2 Programmer [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:986]
picoweb = Picoweb Programming Cable, http://www.picoweb.net/ [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1075]
pony-stk200 = Pony Prog STK200 [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1023]
ponyser = design ponyprog serial, reset=!txd sck=rts mosi=dtr miso=cts [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1265]
siprog = Lancos SI-Prog http://www.lancos.com/siprogsch.html [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1278]
sp12 = Steve Bolt's Programmer [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1063]
stk200 = STK200 [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1007]
stk500 = Atmel STK500 [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:573]
stk500hvsp = Atmel STK500 V2 in high-voltage serial programming mode [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:608]
stk500pp = Atmel STK500 V2 in parallel programming mode [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:601]
stk500v1 = Atmel STK500 Version 1.x firmware [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:580]
stk500v2 = Atmel STK500 Version 2.x firmware [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:594]
stk600 = Atmel STK600 [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:615]
stk600hvsp = Atmel STK600 in high-voltage serial programming mode [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:629]
stk600pp = Atmel STK600 in parallel programming mode [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:622]
usbasp = USBasp, USBasp - USB programmer for Atmel AVR controllers - fischl.de [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:696]
usbasp-clone = Any usbasp clone with correct VID/PID [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:732]
usbtiny = USBtiny simple USB programmer, USBtinyISP - Inexpensive USB AVR Programmer [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:743]
wiring = Wiring [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:344]
xil = Xilinx JTAG cable [C:\Users\steve_hateley\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1116]
Failed uploading: uploading error: exit status 1
Avrdude should get installed with the Arduino IDE, not sure what has gone wrong with your installation, no modifications should be needed.
managed to copy collegue avrdude
avrdude: jtagmkII_initialize(): Cannot locate "flash" and "boot" memories in description
Fixed
had to re copy 4809 zip file into variants folder (over write the original)
from a fellow worker PC
Thanks
Cheers
Steve
