Arduino Nano Every power considerations
Regarding a genuine Arduino Nano Every, I would like to nail a few things down before causing damage to the board or my computer. I have done some searching and found information that hints at the answers I am looking for, however I would just like to get some solid confirmation.
  1. Can the Nano Every be powered externally through the +5V out pin, bypassing the onboard regulator?
  2. If I do this while connected to USB on my computer, will it backfeed voltage to my computer?
Thank you kindly...
Moved your topic to a mores suitable section.
Please take a few moments to Learn and Use The Forum
How to get the best out of this forum Installation & Troubleshooting
Hello, Welcome to the Arduino Forum. This guide explains how to get the best out of this forum. Please read and follow the instructions below. Being new here you might think this is having rules for the sake of rules, but that is not the case. If you don’t follow the guidelines all that happens is there is a long exchange of posts while we try to get you to tell us what we need in order to help you, which is frustrating for you and frustrating for us. The people who try to help with your proâ€Ļ
It will help you get the very best out of the forum in the future.
  • Your OS and version can be valuable information, please include it along with extra security you are using. Antivirus etc.
  • Always list the version of the IDE you are using and the board version if applicable.
  • Use quote or add error messages as an attachment NOT a picture.
  • How to insert an image into your post. ( Thanks sterretje )
  • Add your sketch where applicable but please use CODE TAGS
  • Add a SCHEMATIC were needed even if it is hand drawn
  • Add working links to any specific hardware as needed (NOT links to similar items)
  • Remember that the people trying to help cannot see your problem so give as much information as you can
COMMON ISSUES
  • Ensure you have FULLY inserted the USB cables.
  • Check you have a COMMON GROUND where required. ( Thanks Perry)
  • Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
  • Try other computers where possible.
  • Try other USB leads where possible.
  • You may not have the correct driver installed. CH340/341 or CP2102 or FT232 VCP Drivers - FTDI
  • There may be a problem with the board check or remove your wiring first.
  • Remove any items connected to pins 0 and 1.
COMPUTER RELATED
  • Close any other serial programs before opening the IDE.
  • Ensure you turn off any additional security / antivirus just to test.
  • There may be a problem with the PC try RESTARTING it.
  • You may be selecting the wrong COM port.
  • Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
  • Clear your browsers CACHE.
  • Close the IDE before using any other serial programs.
  • Preferably install IDE’s as ADMINISTRATOR or your OS equivalent
ARDUINO SPECIFIC BOARDS
  • CH340/341 based clones do not report useful information to the “get board info” button.
  • NANO (Old Types) some require you to use the OLD BOOTLOADER option.
  • NANO (ALL Types) See the specific sections lower in the forum.
  • NANO (NEW Types) Install your board CORE’s.
  • Unless using EXTERNAL PROGRAMMERS please leave the IDE selection at default “AVRISP mkII”.
  • Boards using a MICRO usb connector need a cable that is both DATA and CHARGE. Many are CHARGE ONLY.
CREATE editor install locations.
  • On macOs ~/Applications/ArduinoCreateAgent-1.1/ArduinoCreateAgent.app/Contents/MacOS/config.ini
  • On Linux ~/ArduinoCreateAgent-1.1/config.ini
  • On Windows C:\Users[your user]\AppData\Roaming\ArduinoCreateAgent-1.1
Performing the above actions may help resolve your problem without further help.
Language problem ?
Try a language closer to your native language:
Thanks to all those who helped and added to this list.
Bob.
Hello KevinJones,
Thank you for sharing your questions with Arduino community.
Please find answers to your questions below:
It is possible though not recommended under any circumstances. As you said, the current would bypass the voltage regulator and this can damage other parts of the circuit. The board is not designed to be fed through this pin. Use only the designated input pin for this: VIN (voltage input range: 6V to 21V).
  1. If I do this while connected to USB on my computer, will it backfeed voltage to my computer?
There is indeed a possibility that the USB can backfeed voltage straight back to the USB port of your PC thus damaging it.
I hope this was useful.
Regards!
nachoherrera:
Is this germane to the Nano Every?
I am asking this because in this post (My maiden post on this forum) I was actually encouraged to feed power this way, although the responders were mostly referring to Uno and Mega boards. Using the onboard regulator was actually discouraged as it is not capable of delivering much power, and if it is fed by much more than +6v (such as +12v if such a supply were already being used for the project) then the power capacity drops significantly as it is a linear regulator, not allowing much available for even the outputs for the chip. (To be clear I was cautioned against connecting to USB while the board is powered this way, though someone suggested that other boards may have USB back-feed protection - eg, diode.)
So if I have a lot of peripherals that require regulated 5v, the onboard regulator will not be large enough to power them, thus I will need separate supplies, one 5v regulated for the peripherals, and another 6 or so volts to supply the Nano. Also, 6 or 7 volts is a power supply output configuration which is not very common, and as stated, going to the next common output configuation (12v or maybe 9v) lowers the capacity of the onboard regulator.
I'm not meaning to whine here, just stating the challenges I would be faced with if I am unable to power the Nano directly, and the discrepancy against what I've been told regarding the Uno and Mega.
Is it possible the Nano has a more robust voltage regulator, ie, PWM rather than linear?
I should be clear to say I was referring to powering the board with a regulated +5v supply, if that makes a difference.
Looking at the schematic, there is a diode between the USB power input and the 5v line on the board, so it should not backfeed.
david_2018:
Ah yes, I didn't think of hunting for a schematic, but yes you are correct. Thanks!
Hello.
I'd powered, today, Nano Every by external power system, directly on +5v pin's Every. In fact, i put a voltage to 4,95v .
No problem. All work fine whithout any problem. No feedback (diode) on USB port.
jc_buntu:
Hello.
I powered up my Nano Every through the 5V pin, and there was no problem, which seems reasonable to me. The only thing I could imagine I might damage would be the voltage regulator by back-feeding it, but I don't plan to use it anyway.
I was able to read 5V back through the USB port however. The schematic for the vanilla Nano shows a blocking diode, but perhaps the Every does not have one. I did not find a schematic for the Every per se.
Anyway, I am just going to hack a USB cable and disconnect the 5V wire.
KevinJones:
Update: I hacked the USB cable, and everything works fine. I also tested out the regulator, and it appears to still be working. I'll be logging plenty of test time while experimenting to prove it, but I am convinced at this point that this set-up will be just fine.
KevinJones:
I will note that using the hacked USB cable (5V power line disconnected) might be risky if it were connected while the board is not powered up. I suppose a safer approach might be to insert a schottky diode in the cable so it will be assured the board is powered up while sending serial pulses.
