Arduino Nano EVERY reset on serial comm behaviour
Hello,
I used to suffer unvoluntary arduino board reset on Arduino NANO boards when stablishing a serial communication via USB from a Raspberry Pi running linux.
In order to prevent it I used a switch to connect or disconnect a 10 uF capacitor to the reset pin on the NANO board. This is very helpfull to allow uploading new sketches (disconnecting the capacitor from reset pin) or preventing the board reset when stabilish serial comm (by connecting back the capacitor to the reset pin).
This can be checked also with the Serial monitor from the Arduino IDE with the following simple sketch.
int counter;
  counter = 0;
    Serial.print("Counter = ");
    Serial.println(counter);
With this sketch running you'll see that everytime you close the Serial Monitor and open it up, the counter printed on the monitor is reset back to 0.
If you connect the capacitor to the reset pin on the Nano board, you'll see that you can close and open the Arduino IDE Serial monitor and the counter will not reset and continue adding up the values.
So far so good!!! :ok_hand:
The issue appears with Arduino Nano EVERY board. In this case, the capacitor solution on the reset pin seems not to work anymore on this board.
I've read some solutions involving editing the Arduino IDE config files, or solutions that seem to avoid the possibility to further uploading future sketches on the board.
My question is that if there is any solution simillar to the Nano board that allows to easily prevent the reset or let to further upload new sketches by just switching on and off a capacitor.
Also, If interesting to anyone, Arduino Nano EVERY has two Serial monitors associated to the Tx/Rx pins (Serial1) and the USB port (Serial).
Please post schematics to cover the details. Facts like length and type of the serial cable might tell things. Poetry is not the best way.
That's how serial monitor is designed to work. Don't ask why.
Hi @Railroader
Well, it is ok. It seems that there is some kind of bit (DTM or DTR bit I think) that Arduino NANO interprets as a signar to reboot. Which is ok. The thing is that connecting a capacitor on the RESET pin on the NANO prevents it from rebooting and then the Serial monitor from the Arduino IDE cannot reboot the Arduino. This also affects the posibility to upload new sketch on the board. The IDE cannot upload sketches until you remove the capacitor from the RESET pin on the board.
The curious thing is that on the Arduino NANO Every, does not behave the same. And its a pity not being able to block it as easily as the NANO board.
Mu concern is not that the Arduino NANO Every board reboots, but the lack of being to control its behaviour as easy as with the NANO version.
This is outside my comfort zone but maybe other helpers will step in.
