Arduino nano + hc-05 + broadcast and advertise.
I am trying to interface Arduino nano with hc-05 to interact with my application running in my Android phone which listens for a particular advertising data and gets connected with ble. I am using the below BLEPeripheral code to achieve the same. But my Android application is not recognizing the BLE and it is not proceeding beyond the line blePeripheral.begin();. Could you please let me know if it is possible to perform BLE advertise and broadcast using hc-05. Could you please help me on this. Please let me know if you need any additional information.
// Copyright (c) Sandeep Mistry. All rights reserved.
// Licensed under the MIT license. See LICENSE file in the project root for full license information.
//#define SHOW_FREE_MEMORY
#ifdef SHOW_FREE_MEMORY
#include <MemoryFree.h>
#endif
// Import libraries (BLEPeripheral depends on SPI)
#include <SPI.h>
#include <BLEPeripheral.h>
//custom boards may override default pin definitions with BLEPeripheral(PIN_REQ, PIN_RDY, PIN_RST)
BLEPeripheral blePeripheral = BLEPeripheral();
// create service
BLEService testService = BLEService("fff0");
// create counter characteristic
BLEUnsignedShortCharacteristic testCharacteristic = BLEUnsignedShortCharacteristic("fff1", BLERead | BLEWrite | BLEWriteWithoutResponse | BLENotify /| BLEIndicate/);
// create user description descriptor for characteristic
BLEDescriptor testDescriptor = BLEDescriptor("2901", "counter");
// last counter update time
unsigned long long lastSent = 0;
** Serial.begin(9600);**
#if defined (AVR_ATmega32U4)
** delay(5000); //5 seconds delay for enabling to see the start up comments on the serial board**
#endif
** blePeripheral.setLocalName("test");**
#if 1
** blePeripheral.setAdvertisedServiceUuid(testService.uuid());**
#else
** const char manufacturerData[4] = {0x12, 0x34, 0x56, 0x78};**
** blePeripheral.setManufacturerData(manufacturerData, sizeof(manufacturerData));**
#endif
** // set device name and appearance**
** blePeripheral.setDeviceName("Test");**
** blePeripheral.setAppearance(0x0080);**
** // add service, characteristic, and decriptor to peripheral**
** blePeripheral.addAttribute(testService);**
** blePeripheral.addAttribute(testCharacteristic);**
** blePeripheral.addAttribute(testDescriptor);**
** // assign event handlers for connected, disconnected to peripheral**
** blePeripheral.setEventHandler(BLEConnected, blePeripheralConnectHandler);**
** blePeripheral.setEventHandler(BLEDisconnected, blePeripheralDisconnectHandler);**
** // assign event handlers for characteristic**
** testCharacteristic.setEventHandler(BLEWritten, characteristicWritten);**
** testCharacteristic.setEventHandler(BLESubscribed, characteristicSubscribed);**
** testCharacteristic.setEventHandler(BLEUnsubscribed, characteristicUnsubscribed);**
** // set initial value for characteristic**
** testCharacteristic.setValue(0);**
** Serial.println("insideeee11111");**
** // begin initialization**
** blePeripheral.begin();**
** Serial.println("insideeee22222");**
** Serial.println(F("BLE Peripheral"));**
** Serial.print(F("Free memory = "));**
** Serial.println(freeMemory());**
#endif
** BLECentral central = blePeripheral.central();**
** if (central) {**
** // central connected to peripheral**
** Serial.print(F("Connected to central: "));**
** Serial.println(central.address());**
** // reset counter value**
** while (central.connected()) {**
** // central still connected to peripheral**
** if (testCharacteristic.written()) {**
** // central wrote new value to characteristic**
** Serial.println(F("counter written, reset"));**
** lastSent = 0;**
** if (millis() > 1000 && (millis() - 1000) > lastSent) {**
** // atleast one second has passed since last increment**
** lastSent = millis();**
** // increment characteristic value**
** testCharacteristic.setValue(testCharacteristic.value() + 1);**
** Serial.print(F("counter = "));**
** Serial.println(testCharacteristic.value(), DEC);**
** // central disconnected**
** Serial.print(F("Disconnected from central: "));**
void blePeripheralConnectHandler(BLECentral& central) {
** // central connected event handler**
** Serial.print(F("Connected event, central: "));**
void blePeripheralDisconnectHandler(BLECentral& central) {
** // central disconnected event handler**
** Serial.print(F("Disconnected event, central: "));**
void characteristicWritten(BLECentral& central, BLECharacteristic& characteristic) {
** // characteristic value written event handler**
** Serial.print(F("Characteristic event, writen: "));**
void characteristicSubscribed(BLECentral& central, BLECharacteristic& characteristic) {
** // characteristic subscribed event handler**
** Serial.println(F("Characteristic event, subscribed"));**
void characteristicUnsubscribed(BLECentral& central, BLECharacteristic& characteristic) {
** // characteristic unsubscribed event handler**
** Serial.println(F("Characteristic event, unsubscribed"));**
None at all. This is NOT an Arduino problem.
