Arduino nano help! Im rubbish at this!
Hello! I was wondering if anyone can help me -
My aim is to get an LED to slowly brighten to full brightness (255) taking 4 seconds, and then decrease to 0 brightness taking 6 seconds (10 second cycle). I want this to go on for 8 minutes so this cycle would have to happen 48 times. I have the coding for the LED brightness changing which I will paste below: I was wondering if anyone could edit the code for me/add in code to get it to repeat the cycle I already have 48 times and then stop. I have tried googling but I keep messing up the code every time I change it.
#define LED_PIN 5
#define FINISH_PIN 6
#define UP_TIME 4 // In seconds
#define DOWN_TIME 6
uint8_t up_delay = ((UP_TIME * 1000) / 255);
uint8_t down_delay = ((DOWN_TIME * 1000) / 255);
#define ITERATIONS 6
void setup ()
  pinMode(LED_PIN, OUTPUT);
  pinMode(FINISH_PIN, OUTPUT);
  uint8_t i = 0;
  while (i < ITERATIONS)
    // Starting brightness
    uint8_t brightness = 0;
    while (brightness != 255)
      brightness++;
      analogWrite(LED_PIN, brightness);
      delay(up_delay);
    while (brightness != 0)
      brightness--;
      delay(down_delay);
    i++;
  digitalWrite(FINISH_PIN, HIGH);
  while (1);
To repeat the whole cycle 48 times, im guessing you put loops inside another for loop that loops 48 times? I know there isn’t really a way to stop the program (Arduino programmes just keep running void loop forever). But I could add this at the end?:
analogWrite(led,0);
do{
}while(true);
I anyone could help me that would be AMAZING!! Thankyou
if you don't want this forever, then put the code in the setup and and a for loop around it to repeat it 48 times
for (int i = 0; i < 48; i++) {
  for (int b = 0; b <= 255; b++)  {
    analogWrite(LED_PIN, b);
    delay(up_delay);
  for (int b = 254; b >= 0; b--)  {
    delay(down_delay);
I am not sure what you mean by a for loop around it? Would you please mine elaborating ro writing this for me - sorry to be a pain thanks so much
code written above
the englobing for loop repeats 48 times
then you have 2 for loop inside, the first one counts up from 0 to 255 and the second one counts down from 254 (to not repeat 255 twice) to 0
So my void set up now looks like this is this okay:
void setup ()
    delay(up_delay);
    delay(down_delay);
Thanks so much
// My aim is to get an LED to slowly brighten to full
// brightness (255) taking 4 seconds, and then decrease
// to 0 brightness taking 6 seconds (10 second cycle).
// I want this to go on for 8 minutes.
const byte LED_PIN = 5;
const byte FINISH_PIN = 6;
const byte UP_TIME = 4; // In seconds
const byte DOWN_TIME = 6; // In seconds
const byte CYCLE_SECONDS = UP_TIME + DOWN_TIME;
const int up_delay = ((UP_TIME * 1000) / 255);
const int down_delay = ((DOWN_TIME * 1000) / 255);
const byte TOTAL_MINUTES = 8;
const byte ITERATIONS = (TOTAL_MINUTES * 60) / CYCLE_SECONDS;
void setup ()
  for (int iteration = 0; iteration < ITERATIONS; iteration++)
    // Brighten from 0 to 255
    for (int brightness = 0; brightness <= 255; brightness++)
      delay(up_delay);
    // Dim from 255 to 0
    for (int brightness = 255; brightness >= 0; brightness--)
      delay(down_delay);
  } // End for(iteration...
void loop() {}
Meditation lamp? Just curious.
a7
Here's a shot at it..
#include <multiMap.h>
#include <timeObj.h>
#define LED_PIN 5
#define DOWN_TIME    6                    // In seconds
#define FULL_TIME    (UP_TIME+DOWN_TIME)  // In seconds
#define FRAMERATE    20                   // Frames/sec
#define FINISH_TIME  8                    // Minutes for this to run.
multiMap brightnessMapper;                   // A non-linear mapper for brightness values (per ms)
timeObj  changeTimer(1000.0/FRAMERATE);      // A timer to tell us when to change the brightness.
timeObj  finishTimer(FINISH_TIME*60.0*1000); // A timer to tell us when all this nonsens is to stop.
float    msPerFrame;                         // How much time (ms) between brightness changes.
int      iteration;                          // What interation of time are we on now?
void setup () {
   pinMode(LED_PIN, OUTPUT);                       // Setup pulse pin.
   pinMode(FINISH_PIN, OUTPUT);                    // Setup finish pin.
   brightnessMapper.addPoint(0,0);                 // Start brightness at zero (LED off).
   brightnessMapper.addPoint(UP_TIME*1000,255);    // After up time, full on.
   brightnessMapper.addPoint(FULL_TIME*1000,0);    // At the end. (LED off again)
   msPerFrame = 1000.0/FRAMERATE;                  // Calcualte our time, in ms, per bringtness change.
   iteration = 0;                                  // Start the interation count at 0.
   int   brightness;
   float currentTime;
   if (changeTimer.ding()) {                                   // If the change timer has expired..
      changeTimer.start();                                     // We restart it.
      currentTime = iteration * msPerFrame;                    // Caluclate the current time into this pattern.
      brightness = round(brightnessMapper.map(currentTime));   // Using current time, map to the brightness we want.
      //Serial.println(iteration);
      analogWrite(LED_PIN, brightness);                        // Set the LED to that brightness.
      if (currentTime<FULL_TIME*1000.0) {                      // If we have time remaining..
         iteration++;                                          // Bump up the iteration.
      } else {                                                 // else, we are done with the pattern.
         iteration = 0;                                        // Reset the interation back to zero.
   if (finishTimer.ding()) {                                   // If the finish timer has expired..
      analogWrite(LED_PIN, 0);                                 // Shut off the pulse LED.
      digitalWrite(FINISH_PIN, HIGH);                          // Turn on the finished LED.
      changeTimer.reset();                                     // Stop the change timer.
      finishTimer.reset();                                     // Stop the finish timer.
You'll need to install LC_baseTools from the IDE library manger to compile it.
Good luck!
-jim lee
