Arduino nano- how dead is it?
Hello,
I just accidentally dropped my project, and from the fast glimpse I got , it looked like the RT-TX pins at the edge of the board touched the +12V external supply pad (nearby PSU). Now it wont program (or run the previously programmed code). The FTDI usb chip seems to work ok, but I think the 328P-AU is toast. Any ideas on how to verify this? Any possibility that its a software issue?
Thanks
Manos
EDIT: forgot to paste the verbose upload output, trying to upload blink
Binary sketch size: 998 bytes (of a 30720 byte maximum)
/usr/share/arduino/hardware/tools/avrdude -C/usr/share/arduino/hardware/tools/avrdude.conf -v -v -v -v -patmega328p -carduino -P/dev/ttyUSB0 -b57600 -D -Uflash:w:/tmp/build5467184855803561433.tmp/Blink.cpp.hex:i
avrdude: Version 5.10, compiled on Jun 29 2010 at 03:44:14
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/usr/share/arduino/hardware/tools/avrdude.conf"
User configuration file is "/home/vosk/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: Send: 0 [30] [20]
avrdude: ser_recv(): programmer is not responding
avrdude done. Thank you.
It's probably Get A New Nano time, but --
Does "5V" still output 5V OK?
Does "3V3" still output 3.3V OK?
Thank you for the concern,
Yes, I forgot to mention this... Both voltages measure fine, and the board powers on using Vin pin (this is where the 12V) and also using usb. I measured the resistance of the rx tx pins (to gnd) and they are around 9-10M?.
EDIT: power on= power led is on
Since power is good but the program doesn't run then indications are that it's lost.
Thank you! Its time I get another nano, and maybe another atmega328 and try the Arduino-as-ISP confoguration to revive the old one!
