Arduino nano Input connecting
So i have arduino nano
and i have some i dont know name , fingerprint microchip
and this fingerprint microchip output sends + and -
How do i connect this output to arduin nano input
I dont wonna burn somting
Do i connect this + from fingerprint to arduino nano input , and gnd to arduino gnd ? or how
and do i need to put resistor or what ?
upload widget
Rather than a simple pain type picture a REAL picture of the device would be much better along with any markings that are on it.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
It is simple
This module sends output for like solenoid ,
But i need this output to be arduino input
How to connect this output to arduino input , because it has + and - wire
yes but can we have a REAL picture of the device not the super simple schematic.
"some microchip" means nothing.
It could be sending out signals the Arduino cannot accept ?
It could need a special library ?
It is rare for them to just send out an ON OFF pulse as a single shot without first having being told somehow to do that.
PLEASE use the links I provided to help us to help you !
When fingerprint is accepted it sends power 5v 500mA max to output for 5 seconds
for like solenoid , motor or whatever
But i will not attach anything need to attach this output to arduino input ,
When fingerprint is accepted it will send 5v out to arduino input ,...
First measure the actual output to make sure it is <= 5 volts.
If it is slightly over 5 volts a small resistor would be advisable to lower it to <=5 volts.
Then you can use any of the digital pins to read that as an input high or low.
Do i need to connect ground ?
Because 2 wires + and - coming out from fingerprint output
Yes you do.
ok tnx , i try :slight_smile:
