Arduino nano IOT keeps breaking, connection with wifi module failed
Hello!
I trying to create a touch sensor that sends OSC data over wifi. It workes just fine until like 4 or 5th time i start it, and then suddenly the code stops at the "communication with wifi module failed". This has happened with three different arduinos now, and every time it works a couple of times when try with a new one and then this happens. Pasted the code below
#include <touch_config_samd.h>
#include <touch_api_SAMD.h>
#include <Arduino_MCHPTouch.h>
#include <DataStreamer.h>
#include <SLIPEncodedSerial.h>
#include <OSCData.h>
#include <OSCBundle.h>
#include <OSCBoards.h>
#include <OSCTiming.h>
#include <OSCMessage.h>
#include <OSCMatch.h>
#include <SLIPEncodedUSBSerial.h>
#include <SPI.h>
#include <WiFiNINA.h>
#include <WiFi.h>
#include <WiFiUdp.h>
#include <SPI.h>
#include "Arduino_MCHPTouch.h"
// WIFI
//#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = "mias iphone";        // your network SSID (name)
char pass[] = "password";    // your network password (use for WPA, or use as key for WEP)
int status = WL_IDLE_STATUS;     // the WiFi radio's status
WiFiUDP Udp;
//the Arduino's IP
IPAddress ip(172, 20, 10, 2);
//destination IP
IPAddress outIp(172, 20, 10, 5);
const unsigned int outPort = 57121;    // local port to listen on
int count = 0;
    Udp.begin(8080);
  //Initialize serial and wait for port to open:
   while (!Serial)
     // wait for serial port to connect. Needed for native USB port only
  // check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
    Serial.println("Please upgrade the firmware");
  // attempt to connect to WiFi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WPA SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  // you're connected now, so print out the data:
  Serial.print("You're connected to the network");
 //while (!Serial)
  //Set custom sensitivity on X channel
  //TOUCH.setSensorsSensitivity(*newSensitivity*, channel);
  TOUCH.setSensorsSensitivity(1000, 0);
  TOUCH.setSensorsSensitivity(1023, 1);
  // QTouch initialization
  if (!TOUCH.begin())
    Serial.println("Error in sensors initialization!");
    while (1)
  Serial.println("Touch initialization Done!");
  // polling the sensor for new measure
  TOUCH.poll();
  // Checks if new data are available
  if (TOUCH.available())
    //reads sensors
    Serial.print("Sensor 1 status: ");
    Serial.println(TOUCH.read(0));
    Serial.print("Sensor 2 status: ");
    Serial.println(TOUCH.read(1));
    delay(100);
  //the message wants an OSC address as first argument
  OSCMessage msg("/imusic/play/instrument1A");
  msg.add(TOUCH.read(0));
  Udp.beginPacket(outIp, outPort);
    msg.send(Udp); // send the bytes to the SLIP strea
  Udp.endPacket(); // mark the end of the OSC Packet
  msg.empty(); // free space occupied by message
    OSCMessage msg2("/imusic/play/instrument1B");
  msg2.add(TOUCH.read(1));
    msg2.send(Udp); // send the bytes to the SLIP strea
  msg2.empty(); // free space occupied by message
  delay(100);
