Arduino Nano IoT33 Disconnecting and Connecting in Arduino Cloud
I want to upload a sketch to my Arduino Nano IoT33 and see if it print out the GPS coordinates to the serial but when I upload the sketch and then open the serial monitor the Arduino Nano IoT33 just disconnect and connects and it doesn't stop and when I close the serial monitor then if connects and doesn't disconnects.
This is the code in the sketch:
#include <NMEAGPS.h>
#include <GPSport.h>
#include <Streamers.h>
#include "thingProperties.h"
static NMEAGPS  gps;
static gps_fix  fix;
static void doSomeWork()
  trace_all( DEBUG_PORT, gps, fix );
static void GPSloop()
  while (gps.available( gpsPort ))
    fix = gps.read();
    doSomeWork();
  initProperties();
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  DEBUG_PORT.begin(9600);
  while (!DEBUG_PORT);
  DEBUG_PORT.print( F("NMEA.INO: started\n") );
  DEBUG_PORT.print( F("  fix object size = ") );
  DEBUG_PORT.println( sizeof(gps.fix()) );
  DEBUG_PORT.print( F("  gps object size = ") );
  DEBUG_PORT.println( sizeof(gps) );
  DEBUG_PORT.println( F("Looking for GPS device on " GPS_PORT_NAME) );
  #ifndef NMEAGPS_RECOGNIZE_ALL
    #error You must define NMEAGPS_RECOGNIZE_ALL in NMEAGPS_cfg.h!
  #endif
  #ifdef NMEAGPS_INTERRUPT_PROCESSING
    #error You must *NOT* define NMEAGPS_INTERRUPT_PROCESSING in NMEAGPS_cfg.h!
  #endif
  #if !defined( NMEAGPS_PARSE_GGA ) & !defined( NMEAGPS_PARSE_GLL ) & \
      !defined( NMEAGPS_PARSE_GSA ) & !defined( NMEAGPS_PARSE_GSV ) & \
      !defined( NMEAGPS_PARSE_RMC ) & !defined( NMEAGPS_PARSE_VTG ) & \
      !defined( NMEAGPS_PARSE_ZDA ) & !defined( NMEAGPS_PARSE_GST )
    DEBUG_PORT.println( F("\nWARNING: No NMEA sentences are enabled: no fix data will be displayed.") );
  #else
    if (gps.merging == NMEAGPS::NO_MERGING)
      DEBUG_PORT.print  ( F("\nWARNING: displaying data from ") );
      DEBUG_PORT.print  ( gps.string_for( LAST_SENTENCE_IN_INTERVAL ) );
      DEBUG_PORT.print  ( F(" sentences ONLY, and only if ") );
      DEBUG_PORT.println( F(" is enabled.\n"
                            "  Other sentences may be parsed, but their data will not be displayed.") );
  #endif
  DEBUG_PORT.print  ( F("\nGPS quiet time is assumed to begin after a ") );
  DEBUG_PORT.println( F(" sentence is received.\n"
                        "  You should confirm this with NMEAorder.ino\n") );
  trace_header( DEBUG_PORT );
  DEBUG_PORT.flush();
  gpsPort.begin( 9600 );
  ArduinoCloud.update();
  coords = Location(fix.latitude(), fix.longitude()); // CloudLocation Variable
  GPSloop();
