I know that there is plenty posts with this subject but non of them helped me! I tried a lot, trust me...
I have a brand new Arduino nano (Original one, not a Chinese) and it isnt recognized by the Arduino IDE software, but when Im trying the Arduino Create online web editor , it is recognized!
So why with the IDE software (not online) not recognizing it and with Arduino Create it is ?
I saw in the "Device manager" that this USB port (COM7) is written as "USB Serial Port (COM7)", and although this, in Arduino Create it succeeded to recognize the Arduino Nano.
I need to use the IDE software and not the Arduino Create because in Arduino IDE I have the option to change the processor, and I need to change it to the old bootloader... In Arduino Create, I didn`t find any option to change the processor.
I have another thing to mention which is important... I have also Arduino Uno (Original) and it works perfect! it`s recognized both in IDE software and Arduino Create.
Sketch uses 932 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM7 -b57600 -D -Uflash:w:C:\Users\ovan\AppData\Local\Temp\arduino_build_39614/Blink.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM7
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x8b
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x8b
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x8b
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x8b
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x8b
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x8b
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x8b
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x8b
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x8b
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x8b
I`ve noticed also that in the device manager the port has been configured as 9600 baud rate, while arduino IDE tries to upload sketeches with baud rate of 57600.
I changed it in the device manager to baud rate of 57600 and the problem still remains...
If it’s worked with the on line editor , with the same lead, the board will be ok .
Turn computer off and then on, go straight to the IDE ( not the online one) , go to tools , ports, and select the correct port ( which is not com1).
Again in tools select nano and try and upload blink. ( you can also try nano old bootloader )
Good luck and report back .
