ARDUINO NANO is not working with code
I have been trying to upload code to my Arduino Nano and I keep getting this issue
Sketch uses 1752 bytes (5%) of program storage space. Maximum is 30720 bytes.
Global variables use 28 bytes (1%) of dynamic memory, leaving 2020 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Failed uploading: uploading error: exit status 1
It is not uploading your code. Check if you have the proper board selected. Also the Nano has two different boot loaders, the current and the old bootloader. If it is a china or clone board you probably will need the old one. Try both one should work.
