Arduino Nano isn't working
The problem begins with the Arduino Nano clone resetting itself while running the program I’ve uploaded, after a couple of cycle of resetting itself, it when silent with the POW LED still indicating power is still being supplied.
So I tried to hook it up to my computer with the USB and see if it would respond. My computer (Window 7) detects the device but I did not see any RX, TX or L LED light respond on the NANO, only the POW LED light. The reset button does nothing and I can’t upload any code from my computer either, it would return “resp=0x44” Error.
I don’t know what is wrong with the NANO, and all the search doesn’t brings up anything with similar symptoms, like the NANO just gone silent~
Below is the code if you are interested in what i am doing.
#include <FastLED.h>
#include <U8glib.h>
#define LED_PIN 7
#define COLOUR_ORDER GRB
#define LED_TYPE WS2812B
#define NUM_LEDS 144
#define BRIGHTNESS 42
#define ENC_A A0
#define ENC_B A1
#define ENC_PORT PINC
#define SWT 4
#include "SoftwareSerial.h"
#include "MP3FLASH16P.h"
MP3FLASH16P myPlayer;
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE|U8G_I2C_OPT_DEV_0);
char str[4];
int xpin = A2;
int ypin = A3;
int zpin = A6;
const unsigned long SoundTime[] = {0, 0, 0, 0, 0, 0, 2020, 635, 1718, 691, 543, 581, 508, 641, 984, 2028, 542, 581, 1231, 540};
//  const unsigned long SoundTime = 500;
int SoundTrackTracker = 0;
unsigned long previous_Sound = 0;
int swtState = 0;
int astate, alaststate, counter = constrain(counter, 0, 255);
CRGB leds[NUM_LEDS];
  pinMode (ENC_A, INPUT);
  digitalWrite(ENC_A, HIGH);
  pinMode (ENC_B, INPUT);
  digitalWrite(ENC_B, HIGH);
  pinMode (SWT, INPUT);
  digitalWrite(SWT, HIGH);
  counter = 126;
  //Serial.begin(9600);
  myPlayer.init(3);
  myPlayer.setVolume(25);
  delay(3000); // power-up safety delay
  LEDS.addLeds<LED_TYPE, LED_PIN, COLOUR_ORDER>(leds, NUM_LEDS);
  FastLED.setBrightness(BRIGHTNESS);
  if ( u8g.getMode() == U8G_MODE_R3G3B2 )
    u8g.setColorIndex(255);     // white
  else if ( u8g.getMode() == U8G_MODE_GRAY2BIT )
    u8g.setColorIndex(3);         // max intensity
  else if ( u8g.getMode() == U8G_MODE_BW )
    u8g.setColorIndex(1);         // pixel on
  else if ( u8g.getMode() == U8G_MODE_HICOLOR )
    u8g.setHiColorByRGB(255,255,255);
rotaryEncoder();
OnAndOff();
SoundTrack();
ledColorChange();
u8g.firstPage();
  do
    u8g.setFont(u8g_font_unifont);
    u8g.drawStr( 0, 12, "X Axis: ");
    u8g.drawStr( 60, 12, dtostrf(analogRead(xpin), 2, 2, str));
    u8g.drawStr( 0, 28, "Y Axis: ");
    u8g.drawStr( 60, 28, dtostrf(analogRead(ypin), 2, 2, str));
    u8g.drawStr( 0, 45, "Z Axis: ");
    u8g.drawStr( 60, 45, dtostrf(analogRead(zpin), 2, 2, str));
    u8g.drawStr( 0, 60, "Count: ");
    u8g.drawStr( 60, 60, dtostrf(counter, 2, 2, str));
  while( u8g.nextPage() );
void OnAndOff()
if (digitalRead(SWT) == 0){
  if(swtState == 0){
    for(int i = 0; i < NUM_LEDS; i++){
      if(i == 0){
        myPlayer.playFile(8);
        swtState ++;
        SoundTrackTracker = 8;
    leds[i] = CHSV(counter, 187, 255);
    FastLED.show();
  else {
      SoundTrackTracker = 7;
      myPlayer.stopPlay();
      myPlayer.playFile(7);
      for(int a = 143; a > -1; a--){
        leds[a] = CRGB::Black;
        FastLED.show();
      if(a == 143){
        swtState --;
void rotaryEncoder(){
 int8_t tmpdata;
  tmpdata = read_encoder();
  if( tmpdata ) {
    counter += tmpdata;
void SoundTrack(){
  if(digitalRead(SWT) == 1 && swtState == 1){
    int x = analogRead(xpin);
    int y = analogRead(ypin);
    int z = analogRead(zpin);
    if (y > 730 || y < 230 || x > 730 || x < 230 || z > 730 || z < 230){
        SoundTrackTracker = random(9, 11);
        myPlayer.playFile(SoundTrackTracker);
        previous_Sound = currentMillis;
    else if (y > 600 || y < 330 || x > 600 || x < 330 || z > 600 || z < 330){
        SoundTrackTracker = random(12, 19);
    else if(currentMillis - previous_Sound >= SoundTime[SoundTrackTracker]){
      myPlayer.playFile(6);
      SoundTrackTracker = 6;
void ledColorChange(){
  FastLED.show();
  swtState = 1;
int8_t read_encoder()
  static int8_t enc_states[] = {0,-1,1,0,1,0,0,-1,-1,0,0,1,0,1,-1,0};
  static uint8_t old_AB = 0;
  old_AB <<= 2;                   //remember previous state
  old_AB |= ( ENC_PORT & 0x03 );  //add current state
  return ( enc_states[( old_AB & 0x0f )]);
You really really need to READ THIS POST first.
Then add the large amount of missing information.
