Hello all,
I am at a loss for what I am doing wrong in my attempt to run a dc motor with a rotary encoder, l298N, and Arduino Nano.
Here is the code I am running:
/* Turbofan Driver
This program used an L298N motor driver with a 12VDC motor.
The 20x4 LCD displays motor speed, turbofan speed, and motor voltage.
An encoder is used to control the motor speed.
Press the button to set speed back to zero.
Hold the button for 2 seconds to set the Maximum Fan RPM
Hold the button for 5 seconds to reset the Maximum Fan RPM to uncapped.
Maximum RPM set is remembered inside the program even after power down.
The system uses to following components:
Arduino Nano
L298N Motor Driver
RS-555SH 12VDC Motor (or equivalent)
2004D I2C LCD Screen
20 PPR Rotary Encoder
12VDC Power Supply
1x 10k resistor
1x 100k resistor
ADJUST ALL STATEMENTS WITH '***' IN THE COMMENTS
Written and designed by Adam B Johnson
in British Columbia, Canada
15 January 2021
#define gearRatio 2.27 //fixed gear ratio
#include <Encoder.h> //Might need to download this library. Tools > Manage Libraries > Search for 'Encoder'
#include <LiquidCrystal_I2C.h> //Might also need to download this one in the same way.
#include <EEPROM.h> //This should have been included when you installed Arduino IDE. No downloade needed
//################## Adjust these values accordingly #######################################
#define chB 2 //***pin B of the rotary encoder (channel B)
#define chA 3 //***pin A of the rotary encoder (channel A)
#define motorDir1 9 //***motor direction forward pin to driver
#define motorDir2 10 //***motor direction reverse pin to driver
#define motorPWM 6 //***PWM pin to motor controller
#define pushButton 7 //***Button pin
#define voltPin A0 //***Analog pin for motor voltage measurement
#define arduinoVoltage 4.98 //***Actual measured 5 volt pin from the arduino
#define R1 100500.0 //***Actual resistance of 100k resistor
#define R2 9930.0 //***Actual resistance of 10k resistor
float rpmPerVolt = (4825 / 12); //***DC motor max RPM (4825) divided by max voltage (12VDC. Measure both paraments and adjust
LiquidCrystal_I2C lcd(0x3F, 20, 4); //***Adjust screen address if needed. Use File > Examples > Wire > i2c_scanner to acquire address and change 0x3F as needed.
//################## End of adjustable parameters #######################################
int eeAddress = 0;
int pwmMax;
int pwmVal = 0;
bool setFlag = false;
int fanSpeed = 0; //speed of the turbofan in RPM
int mtrSpeed = 0; //speed of the motor in RPM
int deadBand = 20; //minimum PWM signal for the motor to move
float vout = 0.0; //Voltage out of the motor
float roughVoltage = 0.0;
int avgInst = 350; //this should equal the sizeof(tempArray)
int voltCount = 0;
float tempArray[350]; //temp array for averaging voltage readings: array size = number of averaging points
float finalVolt = 0.0; //averaged result
float oldVolt = 0.0; //check to see if voltage changes after each loop
long timeNew = 0; //time stamp at beginning of loop
long timeOld = 0; //time stamp at end of end
long tempTimer = 0;
long oldPos = 0; //old position of the encoder
long newPos = 0; //new position of the encoder
Encoder myEncoder(chA, chB);
//Serial.begin(115200);
pinMode(voltPin, INPUT);
pinMode(motorDir1, OUTPUT);
pinMode(motorDir2, OUTPUT);
pinMode(motorPWM, OUTPUT);
pinMode(pushButton, INPUT_PULLUP);
pinMode(chA, INPUT_PULLUP);
pinMode(chB, INPUT_PULLUP);
myEncoder.write(oldPos);
digitalWrite(motorDir1, HIGH); //motor direction (FWD = HIGH). DON'T CHANGE. SWITCH THE WIRES IF DIRECTION IS WRONG
digitalWrite(motorDir2, LOW); //motor direction (REV = LOW). DON'T CHANGE. SWITCH THE WIRES IF DIRECTION IS WRONG
analogWrite(motorPWM, 0);
lcd.init();
lcd.setCursor ( 3, 0 );
lcd.print("Turbofan Driver");
lcd.setCursor ( 0, 2 );
lcd.print("Adam B. Johnson");
lcd.setCursor( 0, 3);
lcd.print("BC, Canada");
lcd.setCursor ( 16, 3 );
lcd.print("2021");
delay(4500);
lcd.clear();
screenSetup();
zeroNums();
printSpeeds();
printVoltage();
myEncoder.write(0);
newPos = myEncoder.read() ;
timeNew = millis();
EEPROM.get(eeAddress, pwmMax);
if (voltCount < avgInst) {
vout = (analogRead(voltPin) * arduinoVoltage) / 1024.0; //Measure your 5VDC rail to ground with your DMM. Change 4.98 to whatever yours is
roughVoltage = vout / (R2 / (R1 + R2));
tempArray[voltCount] = roughVoltage;
voltCount = 0;
if (newPos > 0) {
//Serial.println(newPos);
if (timeNew - timeOld > 300) {
finalVolt = 0.0;
for (int i = 0; i < avgInst; i++) {
finalVolt += tempArray[i];
timeOld = timeNew;
finalVolt = finalVolt / avgInst;
if (abs(finalVolt - oldVolt) > 0.03) {
mtrSpeed = rpmPerVolt * finalVolt;
fanSpeed = mtrSpeed / gearRatio;
oldVolt = finalVolt;
clearNums();
printVoltage();
printSpeeds();
voltCount++;
if ((newPos != oldPos) && (newPos > 0) && (newPos < pwmMax - deadBand)) {
pwmVal = newPos + deadBand;
analogWrite(motorPWM, pwmVal);
oldPos = newPos;
if ((newPos != oldPos) && (newPos <= 0) && (newPos < pwmMax - deadBand)) {
delay(250);
myEncoder.write(0);
clearNums();
zeroNums();
delay(50);
myEncoder.write(0);
if ((newPos != oldPos) && (newPos > 0) && (newPos >= pwmMax - deadBand)) {
myEncoder.write(4 * (pwmMax - deadBand));
pwmVal = pwmMax;
oldPos = pwmMax - deadBand;
mtrSpeed = mtrSpeed = rpmPerVolt * finalVolt;
if (digitalRead(pushButton) == LOW) {
//Serial.print("buttonPressed");
delay(25);
//Serial.print("buttonStillPressed");
setFlag = false;
EEPROM.put(eeAddress, pwmVal);
for (int i = 0; i < 20; i++) {
lcd.setCursor(i, 0);
lcd.print(" ");
lcd.setCursor(1, 0);
lcd.print("Max Speed Set: ");
lcd.setCursor(16, 0);
lcd.print(fanSpeed);
delay(3000);
EEPROM.put(eeAddress, 255);
lcd.print(" ");
lcd.setCursor(2, 0);
lcd.print("Max Speed Reset");
delay(3000);
lcd.print(" ");
lcd.setCursor(3, 0);
lcd.print("Turbofan Stats");
setFlag = true;
if (setFlag == false) {
myEncoder.write(0);
clearNums();
zeroNums();
setFlag = true;
void printVoltage() {
if ((finalVolt > 0) && (finalVolt < 10.0)) {
lcd.setCursor (12, 3 );
} else if ((finalVolt < 15.0) && (finalVolt >= 10.0)) {
lcd.setCursor (11, 3 );
finalVolt = 0;
lcd.print(finalVolt, 2);
void printSpeeds() {
if (fanSpeed < 100 && fanSpeed >= 10) {
lcd.setCursor(14, 1);
} else if (fanSpeed < 1000 && fanSpeed >= 100) {
lcd.setCursor (13, 1 );
} else if (fanSpeed < 10000 && fanSpeed >= 1000) {
lcd.setCursor (12, 1 );
} else if (fanSpeed == 0) {
lcd.setCursor (15, 1 );
fanSpeed = 0;
if (mtrSpeed < 100 && mtrSpeed >= 10) {
lcd.setCursor(14, 2);
} else if (mtrSpeed < 1000 && mtrSpeed >= 100) {
lcd.setCursor (13, 2 );
} else if (mtrSpeed < 10000 && mtrSpeed >= 1000) {
lcd.setCursor (12, 2 );
} else if (mtrSpeed == 0) {
lcd.setCursor (15, 2 );
mtrSpeed = 0;
lcd.print(mtrSpeed);
void clearNums() {
for (int i = 11; i < 17; i++) {
for (int j = 1; j < 4; j++) {
lcd.setCursor (i, j);
lcd.print(" ");
void zeroNums() {
oldPos = 0;
mtrSpeed = 0;
fanSpeed = 0;
finalVolt = 0;
delay(100);
printSpeeds();
printVoltage();
void screenSetup() {
lcd.setCursor ( 0, 1 );
lcd.print("Fan Speed:");
lcd.setCursor (17, 1 );
lcd.print("RPM");
lcd.print("Mtr Speed:");
lcd.setCursor (17, 2 );
lcd.print("RPM");
lcd.setCursor ( 0, 3 );
lcd.print("Voltage:");
lcd.setCursor (17, 3 );
lcd.print("VDC");
I'm using this schematic:
and here is the pictures with the actual arduino/module driver/encoder setup:
The DC motor I'm using is this:
https://www.parts-express.com/Mabuchi-Type-Motor-RS-555SH-12V-DC-Motor-9-15V-57mm-x-36mm-125-566
Encoder:
So I've checked all my continuity and voltage and everything looks good, but I can't get the DC motor to run via the rotary encoder no matter what I do. The encoder works fine with the arduino (by using the example code), same with the screen. I've verified the dc motor works by using a different L298N as well.
Can someone please help me here? It's driving me absolutely crazy that I can't get this to work and I'm out of options. Maybe something wrong with the way I have everything connected? Bad L298N driver? Bad code?
