Arduino Nano LEDs
I am looking at this chart:
http://forum.arduino.cc/index.php?topic=147582.0
I connected 3 LEDs to pins A4, A5 and A6 through 220 ohm resistors, in source mode.
What pin numbers are associated with pins labeled A4, A5 and A6 in Arduino programming language?
Can those pins be used for digital output at all?
When I use digitalWrite(); command, every pin has a number, associated with it.
What number from this chart do I use to know what is the address of all my D2...D13 and A0...A7 pins?
I am using 17,18,19,20 for button inputs and they are A0, A1, A2, A3. Can I use A4,A5,A6 as LED output pins?
Thanks.
A0 = D14
A5 = D19
A6, A7 are analog input ONLY. Hardware limitation of the '328P chip.
CrossRoads:
A0 = D14
A5 = D19
Does that chart mention the hardware limitation?
I can't see the chart from this connection.
Thank you.
I think that I got things to work.
It was a hardware problem, I suspect.
