Arduino Nano MATLAB Serial communication
I am trying to sample data a sensor connected to a Nano (with a CH340 chip) in MATLAB. I am trying to use serial communication through USB to do this at 38400 baud. The problem I am having is that whilst the data from my sensor looks correct in the serial monitor the data I get in MATLAB is delayed by ~1 second and often I get the same signal twice within my MATLAB data. The exact same code (other than change port) works perfectly on an Uno. I have tried two different Nanos and installed the CH340 drivers and none of this fixed the problem. Any help would be greatly appreciated.
ARDUINO CODE
int16_t data;
Serial.begin(38400);
MMG = analogRead(A1);
Serial.println(data);
MATLAB CODE
s1 = serial('COM13');
s1.BaudRate=38400;
fopen(s1);
for i=1:20000
read=fscanf(s1);
data(i)=str2double(read);
end
Your Arduino code won't even compile. So, that's clearly NOT the code you are running.
