arduino Nano + mcp2515 + tja1050 coryjfowler can not get work
Hi i'm trying to make mcp2515 work (cheap chinese board with tja1050 and 8mhz oscillator) with arduino nano.
connection:
NANO-------board
d8-----------int
d10----------ss
d11----------si
d12----------so
d13----------sck
gnd----------gnd
5v----------- Vcc
I'm using coryjfowler library and I'm trying loopback example, obviously modifying int pin 2-> 8 and sck pin 10-> 13
The sketch:
/* CAN Loopback Example
 * This example sends a message once a second and receives that message
 *   no CAN bus is required.  This example will test the functionality
 *   of the protocol controller, and connections to it.
 *   Written By: Cory J. Fowler - October 5th 2016
#include <mcp_can.h>
#include <SPI.h>
// CAN TX Variables
unsigned long prevTX = 0;                                        // Variable to store last execution time
const unsigned int invlTX = 1000;                                // One second interval constant
byte data[] = {0xAA, 0x55, 0x01, 0x10, 0xFF, 0x12, 0x34, 0x56};  // Generic CAN data to send
// CAN RX Variables
long unsigned int rxId;
unsigned char len;
unsigned char rxBuf[8];
// Serial Output String Buffer
char msgString[128];
// CAN0 INT and CS
#define CAN0_INT 8                              // Set INT to pin 2
MCP_CAN CAN0(13);                               // Set CS to pin 10
  Serial.begin(115200);  // CAN is running at 500,000BPS; 115,200BPS is SLOW, not FAST, thus 9600 is crippling.
  // Initialize MCP2515 running at 16MHz with a baudrate of 500kb/s and the masks and filters disabled.
  if(CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_8MHZ) == CAN_OK)
    Serial.println("MCP2515 Initialized Successfully!");
    Serial.println("Error Initializing MCP2515...");
  // Since we do not set NORMAL mode, we are in loopback mode by default.
  //CAN0.setMode(MCP_LOOPBACK);
  pinMode(CAN0_INT, INPUT);                           // Configuring pin for /INT input
  Serial.println("MCP2515 Library Loopback Example...");
  if(!digitalRead(CAN0_INT))                          // If CAN0_INT pin is low, read receive buffer
    CAN0.readMsgBuf(&rxId, &len, rxBuf);              // Read data: len = data length, buf = data byte(s)
    if((rxId & 0x80000000) == 0x80000000)             // Determine if ID is standard (11 bits) or extended (29 bits)
      sprintf(msgString, "Extended ID: 0x%.8lX  DLC: %1d  Data:", (rxId & 0x1FFFFFFF), len);
      sprintf(msgString, "Standard ID: 0x%.3lX       DLC: %1d  Data:", rxId, len);
    Serial.print(msgString);
    if((rxId & 0x40000000) == 0x40000000){            // Determine if message is a remote request frame.
      sprintf(msgString, " REMOTE REQUEST FRAME");
      for(byte i = 0; i<len; i++){
        sprintf(msgString, " 0x%.2X", rxBuf[i]);
  if(millis() - prevTX >= invlTX){                    // Send this at a one second interval.
    prevTX = millis();
    byte sndStat = CAN0.sendMsgBuf(0x100, 8, data);
    if(sndStat == CAN_OK)
      Serial.println("Message Sent Successfully!");
      Serial.println("Error Sending Message...");
  END FILE
I have doubly checked connections and tested continuity between mcp board and arduino and everything seems correct.
the result I get on the com port is always this:
Entering Configuration Mode Failure...
what am I doing wrong? please help me I don't know what I missed ... Thanks to those who want to help me greetings
Try fixing this line
i use 13 according to nano pinout is it wrong?
deg87:
The number you need is the pin used for slave select (SS).
Your wiring diagram says "d10----------ss"
it works !!!!
I was sure that the pin
MCP_CAN CAN0 (x);
should be connected to sck, what a stupid mistake ... :confused:
Thank you very much you have been very kind. Now I try to see if I get something on can bus :slight_smile: :slight_smile:
