Arduino Nano // Neo-6m-GPS // 4-7 segment display
Hi everyone, i am trying to code the Neo 6m GPS with arduino nano and 4 7 segment display, i have activated display but its not working properly can anyone look into it for making it 4 display as well as proper GPS location.
#include <TinyGPS.h>
#include <SoftwareSerial.h>
TinyGPS gps;
SoftwareSerial ss(A0,A1);
int GPSBaudrate = 9600;
bool *digits[5];
int anodePins[4] = {2, 3, 4, 5};
// cathode pins       A  B C D E F G
int cathodePins[8] = {6, 7, 8, 9, 10, 11, 12, 13};
bool segments[17][7] = {
  {0,0,0,0,0,0,1},
  {1,0,0,1,1,1,1},
  {0,0,1,0,0,1,0},
  {0,0,0,0,1,1,0},
  {1,0,0,1,1,0,0},
  {0,1,0,0,1,0,0},
  {0,1,0,0,0,0,0},
  {0,0,0,1,1,1,1},
  {0,0,0,0,0,0,0},
  {0,0,0,0,1,0,0},
  {0,0,0,0,0,1,0},
  {1,1,0,0,0,0,0},
  {0,1,1,0,0,0,1},
  {1,0,0,0,0,1,0},
  {0,1,1,0,0,0,0},
  {0,1,1,0,0,0,0},
  {0,1,1,1,0,0,0},
long timer1 = 0;
long timer2 = 0;
int count = 0;
int currentAnode = 0;
bool newData = false;
  //set pins to OUTPUT
  for(int i = 0; i < 7; i++){
    pinMode(cathodePins[i], OUTPUT);
    digitalWrite(cathodePins[i], HIGH);
  for(int i = 0; i < 4; i++){
    pinMode(anodePins[i], OUTPUT);
    digitalWrite(anodePins[i], LOW);
  ss.begin(GPSBaudrate);
void displayNumber(int num){
  digits[0] = segments[int(num % 10)];
  digits[1] = segments[int(num / 10) % 10];
  digits[2] = segments[int(num / 100) % 10];
  digits[3] = segments[int(num / 1000) % 10];
//Show one of the digits
void showDigit(int anode){
  digitalWrite(anodePins[((anode+1) % 3)], LOW);
  digitalWrite(anodePins[((anode+2) % 3)], LOW);
  digitalWrite(anodePins[((anode+3) % 3)], LOW);
    digitalWrite(cathodePins[i], !digits[anode][i]);
  digitalWrite(anodePins[anode], HIGH);
  while(ss.available()){
    char c = ss.read();
    Serial.print(c);
    if(gps.encode(c)){
      newData = true;
  //change the anode pin every 1 milisecond
  if(abs(micros() - timer1) > 1000){
    currentAnode = (currentAnode + 1)% 3;
    showDigit(currentAnode);
    timer1 = micros();
  //increment every 1.0s
  if(abs(millis() - timer2) > 1000){
    if(!newData){
      count++;
      if(count > 3){
        displayNumber(404);
    }else{
      count = 0;
      displayNumber(int(gps.f_speed_kmph()));
    timer2 = millis();
I have trying this to prepare for speedometer based vehicle performance.
I have used normal pin diagram configuration for seven segment display
You have eight cathodePins.
And that is . . .?
What do you mean by that?
What is currently not proper about the GPS location?
Incorrectly omitting current limiting resistors. :slight_smile:
