Arduino NANO not recognized
I have bought an Arduino Nano EVERY and i've installed the driver needed for Windows 10, the Arduino megaAVR Boards. It is well conected to the computer, and it has the "power" light on an the Builtin led blinks, because of the pre-installed program. But still, the Arduino IDE doesn't detect my Board, and eighther in the arduino create web editor. I hpoe someone reads this and helps me with my problem.
I'm not an EVERY user.
Is there anything in Windows device manager when you connect the board?
@Kyrpy
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Posting tips.
  • Always list the version of the IDE you are using and the board version if applicable.
  • How to insert an image into your post. ( Thanks Robin2 )
  • Add your sketch where applicable but please use CODE TAGS ( </> )
  • Add a SCHEMATIC were needed even if it is hand drawn
  • Add working links to any specific hardware as needed (NOT links to similar items)
  • Remember that the people trying to help cannot see your problem so give as much information as you can
  1. Does your nano every is updated to the mega AVR boards 1.8.5 version?
  2. Can you see the board under the ports in Device Manager if using windows?
  3. Make sure you are using the latest version of Arduino IDE 1.8.11.
