Arduino Nano not uploading code..I've tried everything!
Arduino: 1.8.12 (Mac OS X), Board: "Arduino Nano, ATmega328P"
Sketch uses 924 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/private/var/folders/l_/5b0fmc1n7w15tzc_0y5tglzw0000gn/T/AppTranslocation/02D9B885-8CF2-404D-A626-B974A1090855/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/private/var/folders/l_/5b0fmc1n7w15tzc_0y5tglzw0000gn/T/AppTranslocation/02D9B885-8CF2-404D-A626-B974A1090855/d/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbserial-AM00GPP4 -b115200 -D -Uflash:w:/var/folders/l_/5b0fmc1n7w15tzc_0y5tglzw0000gn/T/arduino_build_850334/Blink.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/private/var/folders/l_/5b0fmc1n7w15tzc_0y5tglzw0000gn/T/AppTranslocation/02D9B885-8CF2-404D-A626-B974A1090855/d/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/tjneuenfeldt/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.usbserial-AM00GPP4
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
I'm using an Arduino Nano, I recently had a short circuit, but it still worked after that. Suddenly, the Nano wouldn't upload any code, but it could compile. I looked at all the forums (boot-loader doesn't work, I've tried reseting and my port is recognized, so my driver isn't the issue I think). I removed all my wires and am just using the Blink sketch with the built in LED to just figure out this issue. I know there are thousands of posts, but none have worked! Please help!
What has changed since it last worked ?
  • computer updated?
  • different USB cable ?
    -power led on ?
  • Arduino software changed on computer?
    -Nano could be dead, try another ?
    -computer USB port working ok ?
  • try to re load boot loader or program via the icsp connector with a programmer or Arduino as ISP.
  • what was that “short” ? How do you know the NANO worked ok afterwards ?
