Hello! I have a Arduino Nano clone, I was uploading some code but it doesn't upload, There isn't a error, It says "Uploading..." but never finishes, I thought maybe it was my code, so I tried uploading a Blink sketch but nothing, It powers on but only that, I tried burning a new bootloader but nothing ever happened
which OS on your computer? Does the OS see the board when you plug it into the USB port?
Does the clone use a CH340 serial chip ? if so do you have (need?) the driver?
The OS sees the board, I am using windows 10, and I don't know whether this uses the CH340 serial chip, how can I check?
If the OS sees the board as a virtual com port that’s a good sign that you don’t need a driver
Which board did you select in the IDE? Some nano clones require the old bootloader
