I'm working with Arduino Nano v3 (clone) to build a self-balancing robot using NRF (transmitter-receiver). The problem is: I burned AMS1117 3.3 since I wrongly wired between Arduino board to AMS (short GND to VCC)
But = I can upload my sketch successfully to THAT Arduino but the wheel not spinning at all. The led shows as expected. Then I try to use the Arduino board to other simple sketch and it works fine but NOT for my self-balancing robot.
Then I buy a new one with the same circuit diagram and codes and everything work as expected. Well, really, I'm dead confused.
Here's the result of sketch uploading:
Sketch uses 17392 bytes (56%) of program storage space. Maximum is 30720 bytes.
Global variables use 764 bytes (37%) of dynamic memory, leaving 1284 bytes for local variables. Maximum is 2048 bytes.
C:\Users\MEDIACOM\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\MEDIACOM\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b57600 -D -Uflash:w:C:\Users\MEDIACOM\AppData\Local\Temp\arduino_build_223407/self_balancing_robot.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\MEDIACOM\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM6
Using Programmer : arduino
Overriding Baud Rate : 57600
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.16
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\MEDIACOM\AppData\Local\Temp\arduino_build_223407/self_balancing_robot.ino.hex"
avrdude: writing flash (17392 bytes):
Writing | ################################################## | 100% 5.01s
avrdude: 17392 bytes of flash written
avrdude: verifying flash memory against C:\Users\MEDIACOM\AppData\Local\Temp\arduino_build_223407/self_balancing_robot.ino.hex:
avrdude: load data flash data from input file C:\Users\MEDIACOM\AppData\Local\Temp\arduino_build_223407/self_balancing_robot.ino.hex:
avrdude: input file C:\Users\MEDIACOM\AppData\Local\Temp\arduino_build_223407/self_balancing_robot.ino.hex contains 17392 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 3.84s
avrdude: verifying ...
avrdude: 17392 bytes of flash verified
avrdude done. Thank you.
