Hi guys,
I need your help please. I just started w/ Arduino a few hours ago and I cant figure out, what I am doing wrong here.
I have 4 inputs and I have copied this Arduino Playground - PcInt to enable interrupt process on any pin.
PCINT code ......
// initialize digital pin LED_BUILTIN as an output.
pinMode(A0, OUTPUT);
pinMode(A1, OUTPUT);
pinMode(A2, OUTPUT);
pinMode(A3, OUTPUT);
pinMode(8, INPUT_PULLUP);
pinMode(9, INPUT_PULLUP);
pinMode(10, INPUT_PULLUP);
pinMode(11, INPUT_PULLUP);
PCattachInterrupt(8, input8, CHANGE);
PCattachInterrupt(9, input9, CHANGE);
PCattachInterrupt(10, input10, CHANGE);
PCattachInterrupt(11, input11, CHANGE);
bool status = true;
int led_press[4];
// the loop function runs over and over again forever
for(int i = 0; i < 4; i++){
Serial.print(led_press[i]);
Serial.print("\n");
void input8(){
led_press[0] = 1;
void input9(){
led_press[1] = 2;
void input10(){
led_press[2] = 3;
void input11(){
led_press[3] = 4;
What is happening is that if I activate pin 8, all functions from input8-11 activate. So if I activate pin 8, led_press is {1, 2, 3, 4} instead of {1, 0, 0, 0}.
Any suggestions? It might be just a stupid mistake I made, but I cannot see it.
THANKS!
The code that you're not displaying, are you sure that you got that correctly? I just compiled and ran (currently still running) the code from the link and it works fine.
Robin2:
Pin change interrupts apply to a group of I/O pins. When the interrupt fires your ISR needs to check which of the pins caused it.
Also I think a single ISR is all that is needed for a group of pins. I say "I think" because I have never used the PCattachInterrupt() function.
...R
I haven't heard about ISR, will check/try it.. anyway THANKS!
DKWatson:
#include "pins_arduino.h"
volatile uint8_t *port_to_pcmask[] = {
&PCMSK0,
&PCMSK1,
&PCMSK2
static int PCintMode[24];
typedef void (*voidFuncPtr)(void);
volatile static voidFuncPtr PCintFunc[24] = {
NULL };
volatile static uint8_t PCintLast[3];
void PCattachInterrupt(uint8_t pin, void (*userFunc)(void), int mode) {
uint8_t bit = digitalPinToBitMask(pin);
uint8_t port = digitalPinToPort(pin);
uint8_t slot;
volatile uint8_t *pcmask;
// map pin to PCIR register
if (port == NOT_A_PORT) {
return;
else {
port -= 2;
pcmask = port_to_pcmask[port];
// -- Fix by Baziki. In the original sources it was a little bug, which cause analog ports to work incorrectly.
if (port == 1) {
slot = port * 8 + (pin - 14);
else {
slot = port * 8 + (pin % 8);
// --Fix end
PCintMode[slot] = mode;
PCintFunc[slot] = userFunc;
// set the mask
*pcmask |= bit;
// enable the interrupt
PCICR |= 0x01 << port;
void PCdetachInterrupt(uint8_t pin) {
return;
else {
port -= 2;
// disable the mask.
*pcmask &= ~bit;
// if that's the last one, disable the interrupt.
if (*pcmask == 0) {
PCICR &= ~(0x01 << port);
// common code for isr handler. "port" is the PCINT number.
// there isn't really a good way to back-map ports and masks to pins.
static void PCint(uint8_t port) {
uint8_t bit;
uint8_t curr;
uint8_t mask;
uint8_t pin;
// get the pin states for the indicated port.
curr = *portInputRegister(port+2);
mask = curr ^ PCintLast[port];
PCintLast[port] = curr;
// mask is pins that have changed. screen out non pcint pins.
if ((mask &= *port_to_pcmask[port]) == 0) {
return;
// mask is pcint pins that have changed.
for (uint8_t i=0; i < 8; i++) {
bit = 0x01 << i;
if (bit & mask) {
pin = port * 8 + i;
// Trigger interrupt if mode is CHANGE, or if mode is RISING and
// the bit is currently high, or if mode is FALLING and bit is low.
if ((PCintMode[pin] == CHANGE
|| ((PCintMode[pin] == RISING) && (curr & bit))
|| ((PCintMode[pin] == FALLING) && !(curr & bit)))
&& (PCintFunc[pin] != NULL)) {
PCintFunc[pin]();
SIGNAL(PCINT0_vect) {
PCint(0);
SIGNAL(PCINT1_vect) {
PCint(1);
SIGNAL(PCINT2_vect) {
PCint(2);
@Robin2, the code in the reference link seems to have taken care of the pin resolution, allowing for 24 function pointers. Which is pretty good as there are only 20 pin interrupts on the 328p.
DKWatson:
I tried to copy and paste code once again and it is still not working properly. Each pin activates all functions..
