unless a remove request was sent too google.. it could still be indexed that way.
sorry for the late but i've the flu and i'm not ok. Tomorrow i do the work.
Sorry and thanks!
I changed the first post and i'm working in a new version.
pighixxx, you need to remove the file nanopdf.png attached to the post Arduino NANO Pinout Diagram - #8 by pighixxx - Project Guidance - Arduino Forum.
Please, correct ICSP header pins (physical pins in black) too.
TNX
I'm drawing a new version. It will be ready for this weekend ![]()
Where is the new version with correct ICSP header pins?
Dear pighixx,
It would be nice if you could correct the above mentioned mistakes. It leads to a lot of confusion.
Thank you!
Thomas
Hi everybody!
I wish to know if its possible to connect both bluetooth and ultrasonic directly to the arduino nano.
Cause they both require vcc 5v and in the nano there is only 0ne availble. can i use the vin pin also?
Can i connect two jumpers to the one 5v pin?
Some other option?
Thank you very much!
Rei
Does the file linked to in the OP still contain errors? If so, does anyone know where to find a similar IO schematic without known errors?
