Hi, first of all thans for the help that you do with this forum.
Now, I'm new in this life, making code to arduino hardware our other types of hardware, and I'm making one project in arduino and the result is no the expected..
I'm using Nano (clone) (I have 3) and not all the tests are ok. Some of them do the suposed but the most of the tests fails.. Or the relay from h bridge doesn't work, or the code jumps some steps..
The project consists on 6 buttons (3 analog input which one with 2 buttons with resistors making voltage drop), 2 outputs making rotate one motor (h bridge) to 3 positions (3 magnetic switches), 4 switches for control and 2 outputs making rotate other motor (h bridge)..
I puted anexed the project sketch.
The big wheel is always located on line 1.
Code (anexed also) (I put only 1 line of 3 because the project is to big):
// Pinos dos sensores
#define sensorEstacao1 A0 //line 1 end switch
#define sensorEstacao2 A1 //line 2 end switch
#define sensorEstacao3 A2 //line 3 end switch
#define OticoAgulha 2 //end switch
// Botoes chamada Estacoes
#define ChamadaEstacao1 A4 //select lines on station 1
#define ChamadaEstacao2 A5 //select lines on station 2
#define ChamadaEstacao3 A6 //select lines on station 3
// Pinos leds
int Green = 3; //led green
int Red = 4; //led red
// Pinos motor agulha
int M_esq = 5; //platform left
int M_drt = 6; //platform right
// Pinos aspirante soprante
int aspirante = 7; //train front
int soprante = 8; //train back
// Pinos posicionadores
int posicaoAgulha1 = 11; //magnetic switch line 1
int posicaoAgulha2 = 10; //magnetic switch line 2
int posicaoAgulha3 = 9; //magnetic switch line 3
int valor_posicaoAgulha1;
int valor_posicaoAgulha2;
int valor_posicaoAgulha3;
int valor_sensorEstacao1;
int valor_sensorEstacao2;
int valor_sensorEstacao3;
int valor_OticoAgulha;
int Tempo;
int valorE1;
int valorE2;
int valorE3;
pinMode(ChamadaEstacao1, INPUT_PULLUP);
pinMode(ChamadaEstacao2, INPUT_PULLUP);
pinMode(ChamadaEstacao3, INPUT_PULLUP);
pinMode(sensorEstacao1, INPUT_PULLUP);
pinMode(sensorEstacao2, INPUT_PULLUP);
pinMode(sensorEstacao3, INPUT_PULLUP);
pinMode(posicaoAgulha1, INPUT_PULLUP);
pinMode(posicaoAgulha2, INPUT_PULLUP);
pinMode(posicaoAgulha3, INPUT_PULLUP);
pinMode(soprante, OUTPUT);
pinMode(aspirante, OUTPUT);
pinMode(OticoAgulha, INPUT_PULLUP);
pinMode(Green, OUTPUT);
pinMode(Red, OUTPUT);
pinMode(M_esq, OUTPUT);
pinMode(M_drt, OUTPUT);
digitalWrite(M_drt, HIGH);
digitalWrite(M_esq, HIGH);
digitalWrite(aspirante, HIGH);
digitalWrite(soprante, HIGH);
Tempo = 3000;
valorE1 = analogRead(ChamadaEstacao1);
valorE2 = analogRead(ChamadaEstacao2);
valorE3 = analogRead(ChamadaEstacao3);
// INICIO DE CODIO QUE OBRIGA A AGULHA A FICAR NA ESTACAO 1
if (valor_posicaoAgulha1 == LOW); {
do {
digitalWrite(M_drt, LOW);
valor_posicaoAgulha1 = digitalRead(posicaoAgulha1);
} while (valor_posicaoAgulha1 == HIGH);
if (valor_posicaoAgulha2 == LOW); {
do {
if (valor_posicaoAgulha3 == LOW); {
do {
digitalWrite(Green, LOW);
digitalWrite(Red, HIGH);
// ESTACAO 1
// ENVIAR DA ESTACAO 1 PARA A ESTACAO 2
if (valorE1 >= 900 && valorE1 <= 950) { // Botao da estacao 2 situado na estacao 1
digitalWrite(Green, LOW); // Desliga Led verde e liga vermelho
do {
digitalWrite(aspirante, LOW); // Liga motor aspirante
valor_OticoAgulha = digitalRead(OticoAgulha); // Fica à espera que o turpedo chegue à agulha
} while (valor_OticoAgulha == HIGH);
digitalWrite(aspirante, HIGH); // Assim que chega desliga o aspirante
Serial.println(valor_OticoAgulha);
// delay(Tempo); // Espera 3s para o motor parar
do {
digitalWrite(M_esq, LOW); // Muda a agulha para a estacao 2
valor_posicaoAgulha2 = digitalRead(posicaoAgulha2);
} while (valor_posicaoAgulha2 == HIGH);
digitalWrite(M_esq, HIGH); // Liga motor soprante
Serial.println(valor_posicaoAgulha2);
do {
digitalWrite(soprante, LOW); // Fica à espera que o turpedo chegue à estacao 2
valor_sensorEstacao2 = digitalRead(sensorEstacao2);
} while (valor_sensorEstacao2 == HIGH); // Assim que chega desliga o soprante
Serial.println(valor_sensorEstacao2);
do {
digitalWrite(M_drt, LOW); // Envia a agulha de novo para a estacao 1
digitalWrite(Red, LOW); // Desliga o led vermelho e liga o verde
digitalWrite(Green, HIGH);
// ENVIAR DA ESTACAO 1 PARA A ESTACAO 3
if (valorE1 >= 700 && valorE1 <= 750) { // Botao da estacao 3 situado na estacao 1
do {
do {
digitalWrite(M_esq, LOW); // Muda a agulha para a estacao 3
valor_posicaoAgulha3 = digitalRead(posicaoAgulha3);
} while (valor_posicaoAgulha3 == HIGH);
do {
valor_sensorEstacao3 = digitalRead(sensorEstacao3);
} while (valor_sensorEstacao3 == HIGH); // Assim que chega desliga o soprante
do {
If you can help, I'd be grateful.
And sorry for the bad english, I'm portuguese.
Moderator edit: code tags
projecto.ino (13.2 KB)
