all of the sudden my arduino nano can't be programmed anymore.
I just get this:
Arduino: 1.8.5 (Mac OS X), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
Sketch uses 8936 bytes (29%) of program storage space. Maximum is 30720 bytes.
Global variables use 559 bytes (27%) of dynamic memory, leaving 1489 bytes for local variables. Maximum is 2048 bytes.
/Users/kait/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/bin/avrdude -C/Users/kait/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.wchusbserial1410 -b57600 -D -Uflash:w:/var/folders/0w/v33kz9y56j3_b9r5c38bsk740000gn/T/arduino_build_963793/cn_livingroom.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:01:35
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/kait/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/etc/avrdude.conf"
User configuration file is "/Users/kait/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.wchusbserial1410
Using Programmer : arduino
Overriding Baud Rate : 57600
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.16
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "/var/folders/0w/v33kz9y56j3_b9r5c38bsk740000gn/T/arduino_build_963793/cn_livingroom.ino.hex"
avrdude: writing flash (8936 bytes):
Writing |
avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0x95
avrdude: stk500_cmd(): programmer is out of sync
################################################## | 100% 111.82s
avrdude: 8936 bytes of flash written
avrdude: verifying flash memory against /var/folders/0w/v33kz9y56j3_b9r5c38bsk740000gn/T/arduino_build_963793/cn_livingroom.ino.hex:
avrdude: load data flash data from input file /var/folders/0w/v33kz9y56j3_b9r5c38bsk740000gn/T/arduino_build_963793/cn_livingroom.ino.hex:
avrdude: input file /var/folders/0w/v33kz9y56j3_b9r5c38bsk740000gn/T/arduino_build_963793/cn_livingroom.ino.hex contains 8936 bytes
avrdude: reading on-chip flash data:
Reading | avrdude: loadaddr(): (b) protocol error, expect=0x14, resp=0x00
avrdude: stk500_paged_load(): (a) protocol error, expect=0x14, resp=0x10
avrdude: stk500_cmd(): protocol error
avr_read(): error reading address 0x0000
read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x00
avrdude done. Thank you.
the selected serial port
does not exist or your board is not connected
option enabled in File -> Preferences.
For some reason it looks like the USB-Serial port on that Nano is not working anymore.
I'm not aware of any changed that I made that might cause this. I always was able to program this Arduino. Any ideas on what might have changed that causes this?
I get the same message with just the blink sketch,...
