Hello, I want to ask is it possible to make a signal like this function generator from my Arduino Nano? arduinui hosted at ImgBB — ImgBB
kaspiuxz:
Give some more details about your function generator
1 Hz square wave, 80% duty cycle, 8 volts peak to peak output.
Easy if you're okay with ~4.5 vdc p-p output.
If you need something over the normal output voltage of the Arduino, you would need an NPN transistor, appropriate resistors and a dc power source of the appropriate voltage.
I need it for this. I made it all on breadboard just don’t know how to make arduino that signal(from function generator). https://streamable.com/iulvia
ABD8-B2-C5-6529-44-A7-98-E5-B1-AF5-EECD709 hosted at ImgBB — ImgBB
Is it possible to make it from arduino nano?
