Apart from a 32 pin ZIF socket. Does anyone know of a suitable cheaper socket that will take the 15.24mm wide x 2.54mm pitch (square pinned) Arduino Nano V3.0, 30 pin board?
It would probably need to be a spring loaded DIL rather than a turned pin DIL, ideally from RS Components or Farnell.
I hope to solder the socket into a VERO board rather than solder the Nano directly.
I forgo the square pins and use round so they fit in breadboards without spreading the connectors and they will fit into dip sockets as well. The regular dip socketsl provides a much lower height profile over the usual square pin sockets.
