Hello, I am new using Nextion Screens. I have issue loading the code and my believe is that the problem lies on the serial of RP2040 TX and RX.
when I try to upload/compile the code I get these error:
`C:\Users\Dario\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexUpload.cpp:17:10: fatal error: SoftwareSerial.h: No such file or directory
#include <SoftwareSerial.h>
compilation terminated.
exit status 1
Compilation error: exit status 1`
I am using library of Nextion Master and I have modified the library as recommended:
* Define DEBUG_SERIAL_ENABLE to enable debug serial.
* Comment it to disable debug serial.
//#define DEBUG_SERIAL_ENABLE
* Define dbSerial for the output of debug messages.
#define dbSerial Serial
* Define nexSerial for communicate with Nextion touch panel.
#define nexSerial Serial
that did not work.
here is my complete code:
#include <Nextion.h>
////////////////////////// DECLARE OBJECT VARIABLES: ...
NexButton b0 = NexButton(0, 26, "b0"); // Button added
NexButton b1 = NexButton(0, 27, "b1"); // Button added
NexButton b2 = NexButton(0, 28, "b2"); // Button added
NexButton b3 = NexButton(0, 29, "b3"); // Button added
NexButton b4 = NexButton(0, 30, "b4"); // Button added
NexButton b5 = NexButton(0, 31, "b5"); // Button added
NexButton b6 = NexButton(0, 32, "b6"); // Button added
NexButton b7 = NexButton(0, 33, "b7"); // Button added
// Declare pages:
int variable1 = 0; // Create a variable to have a counter going up by one on each cycle
int counter = 0; // Create a variable to have a counter for the + and - buttons
int CurrentPage = 0; // Create a variable to store which page is currently loaded
NexPage page0 = NexPage(0, 0, "page0"); // Page added as a touch event
// End of declaring objects
//char buffer[100] = {0}; // This is needed only if you are going to receive a text from the display. You can remove it otherwise.
// Further on this sketch I do receive text so that's why I created this buffer.
////////////////////////// END OF DECLARE OBJECT VARIABLES:
////////////////////////// DECLARE INPUTS:
// Analog input pins
#define SENSOR_PIN1 A1
#define SENSOR_PIN2 A2
////////////////////////// END OF DECLARE INPUTS:
////////////////////////// DECLARE OUTPUTS:
//Declare digital outputs
const int modeValveBlowerPin = 2;
const int modeValveDPPin = 3;
const int pistonOpenEnablePin = 4;
const int pistonOpenReleasePin = 5;
const int pistonCloseEnablePin = 6;
const int pistonCloseReleasePin = 7;
const int mainValveOpenPin = 8;
const int mainValveClosePin = 9;
////////////////////////// END OF DECLARE OUTPUTS:
////////////////////////// REGISTER TOUCH EVENT LIST: ...
NexTouch *nex_listen_list[] =
&b0, // Button added
&b1, // Button added
&b2, // Button added
&b3, // Button added
&b4, // Button added
&b5, // Button added
&b6, // Button added
&b7, // Button added
&page0, // Page added as a touch event
NULL // String terminated
}; // End of touch event list
////////////////////////// END OF TOUCH EVENT LIST:
////////////////////////// TOUCHE VENTS:
//-------[B0]
void b0PushCallback(void *ptr) // Press event for button b0
digitalWrite(modeValveDPPin, HIGH); // Turn ON internal LED
} // End of press event
void b0PopCallback(void *ptr) // Release event for button b0
digitalWrite(modeValveDPPin, LOW); // Turn OFF internal LED
} // End of release event
//-------[B1]
void b1PushCallback(void *ptr) // Press event for button b1
digitalWrite(modeValveBlowerPin, HIGH); // Turn ON internal LED
void b1PopCallback(void *ptr) // Release event for button b1
digitalWrite(modeValveBlowerPin, LOW); // Turn OFF internal LED
//-------[B2]
void b2PushCallback(void *ptr) // Press event for button b2
digitalWrite(pistonOpenEnablePin, HIGH); // Turn ON internal LED
void b2PopCallback(void *ptr) // Release event for button b2
digitalWrite(pistonOpenEnablePin, LOW); // Turn OFF internal LED
//-------[B3]
void b3PushCallback(void *ptr) // Press event for button b3
digitalWrite(pistonOpenReleasePin, HIGH); // Turn ON internal LED
void b3PopCallback(void *ptr) // Release event for button b3
digitalWrite(pistonOpenReleasePin, LOW); // Turn OFF internal LED
//-------[B4]
void b4PushCallback(void *ptr) // Press event for button b4
digitalWrite(pistonCloseEnablePin, HIGH); // Turn ON internal LED
void b4PopCallback(void *ptr) // Release event for button b4
digitalWrite(pistonCloseEnablePin, LOW); // Turn OFF internal LED
//-------[B5]
void b5PushCallback(void *ptr) // Press event for button b5
digitalWrite(pistonCloseReleasePin, HIGH); // Turn ON internal LED
void b5PopCallback(void *ptr) // Release event for button b5
digitalWrite(pistonCloseReleasePin, LOW); // Turn OFF internal LED
//-------[B6]
void b6PushCallback(void *ptr) // Press event for button b6
digitalWrite(mainValveOpenPin, HIGH); // Turn ON internal LED
void b6PopCallback(void *ptr) // Release event for button b6
digitalWrite(mainValveOpenPin, LOW); // Turn OFF internal LED
//-------[B7]
void b7PushCallback(void *ptr) // Press event for button b7
digitalWrite(mainValveClosePin, HIGH); // Turn ON internal LED
void b7PopCallback(void *ptr) // Release event for button b7
digitalWrite(mainValveClosePin, LOW); // Turn OFF internal LED
//-------[B...]
// ... Define callbacks for more buttons ...
////////////////////////// END OF TOUCH EVENTS:
////////////////////////// ANALOF READING FUNCTIONS:
// Number of readings to consider for average calculation
const int numReadings = 25;
// Time interval for taking readings (0.1 second)
const unsigned long interval = 100;
unsigned long previousMillis = 0;
// Array to store the readings
float readings1[numReadings];
float readings2[numReadings];
int readIndex = 0;
// Function to map analog readings to a signal range of 0-5V
float mapToSignal(int reading) {
// Map the analog reading from the range 55-1023 to 0-150 (0-150 psi)
return (152.0 * (reading - 25)) / (1023 - 25);
// Function to calculate the average value from the stored readings
float calculateAverage(float readings[]) {
float sum = 0;
for (int i = 0; i < numReadings; i++) {
sum += readings[i];
return sum / numReadings;
////////////////////////// END OF ANALOF READING FUNCTIONS:
// You might need to change NexConfig.h file in your ITEADLIB_Arduino_Nextion folder
// Set the baudrate which is for debug and communicate with Nextion screen
nexInit();
////////////////////////// DEFINE PINS:
pinMode(modeValveBlowerPin, OUTPUT);
pinMode(modeValveDPPin, OUTPUT);
pinMode(pistonOpenEnablePin, OUTPUT);
pinMode(pistonOpenReleasePin, OUTPUT);
pinMode(pistonCloseEnablePin, OUTPUT);
pinMode(pistonCloseReleasePin, OUTPUT);
pinMode(mainValveOpenPin, OUTPUT);
pinMode(mainValveClosePin, OUTPUT);
////////////////////////// END OF DEFINE PINS:
////////////////////////// REGISTER EVENT CALLBACK FUNCTIONS:
// Register the event callback functions of each touch event:
b0.attachPush(b0PushCallback); // Button press
b0.attachPop(b0PopCallback); // Button release
b1.attachPush(b1PushCallback); // Button press
b1.attachPop(b1PopCallback); // Button release
b2.attachPush(b2PushCallback); // Button press
b2.attachPop(b2PopCallback); // Button release
b3.attachPush(b3PushCallback); // Button press
b3.attachPop(b3PopCallback); // Button release
b4.attachPush(b4PushCallback); // Button press
b4.attachPop(b4PopCallback); // Button release
b5.attachPush(b5PushCallback); // Button press
b5.attachPop(b5PopCallback); // Button release
b6.attachPush(b6PushCallback); // Button press
b6.attachPop(b6PopCallback); // Button release
b7.attachPush(b6PushCallback); // Button press
b7.attachPop(b6PopCallback); // Button release
// End of registering the event callback functions
////////////////////////// END OF REGISTER EVENT CALLBACK FUNCTIONS:
readings1[i] = 0;
readings2[i] = 0;
delay(30);
if (currentMillis - previousMillis >= interval) {
int sensorValue1 = analogRead(SENSOR_PIN1);
int sensorValue2 = analogRead(SENSOR_PIN2);
float signal1 = mapToSignal(sensorValue1);
float signal2 = mapToSignal(sensorValue2);
readings1[readIndex] = signal1;
readings2[readIndex] = signal2;
readIndex = (readIndex + 1) % numReadings;
float averageValue1 = calculateAverage(readings1);
float averageValue2 = calculateAverage(readings2);
////////////////////////// Serial PRINT VALUES:
Serial.print(averageValue1, 2);
Serial.print(",");
Serial.print(averageValue2, 2);
Serial.print(",");
Serial.print(150);
Serial.print(",");
Serial.print(0);
Serial.print(",");
if(CurrentPage == 0){ // If the display is on page 0, do the following
Serial.print("n1.val="); // This is sent to the nextion display to set what object name (before the dot) and what atribute (after the dot) are you going to change.
Serial.print(averageValue1, 2); // This is the value you want to send to that object and atribute mentioned before.
Serial.write(0xff); // We always have to send this three lines after each command sent to the nextion display.
Serial.write(0xff);
Serial.write(0xff);
Serial2.print(",");
Serial.print("n2.val="); // This is sent to the nextion display to set what object name (before the dot) and what atribute (after the dot) are you going to change.
Serial.print(averageValue2, 2); // This is the value you want to send to that object and atribute mentioned before.
Serial.write(0xff);
Serial.write(0xff);
////////////////////////// END OF Serial PRINT VALUES:
delay(interval);
could you help me figure what i am doing wrong?
thanks!
