Arduino Nano RS-485 Modbus slave to master write problem
I have been working on simple modbus communication but, I haven't succeeded.
I want to write the value read from the hc-sr04 sensor on the slave device to the master device as boolean according to a thresold value.
I have two Arduino nano and two TTL rs485 converter.
Both Arduino pin connection;
R0 to RX(D0)
DI to TX(D1)
DE and RE to D2
A to A
B to B
Master always print 0, where is the problem? could you help me?
Slave Code
#include "NewPing.h"
    #include <ModbusRTUSlave.h>
    #define TRIGGER_PIN 9
    #define ECHO_PIN 10
    #define MAX_DISTANCE 400
    #define TRESHOLD_DISTINCE 30 //100
    NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
    float duration, distance;
    #define SERIAL_BAUD 38400
    #define SERIAL_CONFIG SERIAL_8N1
    #define SLAVE_ID 1
    #define TXEN	2
    ModbusRTUSlave slave(Serial, TXEN);
    bool discreteInputs[1];
    bool oldStatus = false;
    bool newStatus = false;
      discreteInputs[0] = false;
      Serial.begin( SERIAL_BAUD, SERIAL_8E1 ); // 19200 baud, 8-bits, even, 1-bit stop
      slave.configureCoils(discreteInputs, 1);
      slave.begin(SLAVE_ID, SERIAL_BAUD, SERIAL_8E1);
      distance = sonar.ping_cm();
      Serial.print("DIST ");
      // Send results to Serial Monitor
      distance = distance == 0? 400 : distance;
      if (distance >= 400 || distance <= 2) {
        Serial.print("- |");
        Serial.print(distance);
        Serial.print(" | ");
      if (distance < TRESHOLD_DISTINCE) {
        Serial.print(" PARK F | ");
        newStatus = true;
        Serial.print(" PARK E | ");
        newStatus = false;
      if (oldStatus != newStatus) {
        oldStatus = newStatus;
        discreteInputs[0] = newStatus;
      slave.poll();
Master Code
#include <ModbusRTUMaster.h>
    #define TXEN	2
    ModbusRTUMaster modbus(Serial, TXEN);
      Serial.begin(SERIAL_BAUD);
      modbus.begin(SERIAL_BAUD);
      modbus.readCoils(1, 0, discreteInputs, 1);
      uint8_t reesponse = modbus.getExceptionResponse();
      Serial.print( reesponse );
      Serial.print(" |");
      Serial.print(discreteInputs[0]);
      Serial.print(" |");
Library links
Using the same UART for two different functions (modbus and PC) will not work (or at least not reliably).
