i want to developp a wireless-voc sensor-system. I used tgs2602, arduino Nano and Xbee Pro S1.
This is my arduino-code:
int value ;
const int gasSensor = A0;
int value = analogRead (gasSensor);
float volt = (value/1023.0)*5.0 ; // Rechne die von ADC ausgegebenen Werten in Volt um
float Rs1 = 10*(5-volt)/volt; //Rechne den Widerstandswert
//Serial.print("40B7DEF1"); // Sensorname
//Serial.print("\t"); // Tabulator
// Kalibrierungsarray der Länge N = 17
float Rs [17] = {57.84260516, 2.200081335, 1.606762875, 1.178596714, 0.944910617, 0.865628395, 0.764262648, 0.687566798, 0.626992561, 0.567101091, 0.544815465, 0.496850952, 0.474860336, 0.474860336, 0.442046642, 0.423905489, 0.402219139};
float ppmValue [17] = {0, 5, 10, 15, 20, 24, 28.25, 32.5, 37.75, 43.25, 48.75, 53.25, 57.75, 62.50, 67.50, 75.5, 77.5};
if (Rs1 >= Rs [0])
float ppm = ppmValue [0];
//Serial.print ("ppm: ");
Serial.print("1"); // Sensorname
Serial.println(ppm);
delay(30000);
// Interpolation: ppm [0;5]
if ( Rs[1] < Rs1 && Rs1 < Rs[0]){
float ppm = ppmValue [0] + ((-Rs1 + Rs [0])/(Rs[0] - Rs [1] ))*(ppmValue [1] - ppmValue[0]);
Serial.println (ppm);
delay(30000);
// Interpolation: ppm [5;10]
else if ( Rs[2] < Rs1 && Rs1 < Rs[1]){
float ppm = ppmValue [1] + ((-Rs1 + Rs [1])/(Rs[1] - Rs [2] ))*(ppmValue [2] - ppmValue[1]);
//PPM Ausgabe
delay(30000);
// Interpolation: ppm [10;15]
else if ( Rs[3] < Rs1 && Rs1 < Rs[2]){
float ppm = ppmValue [2] + ((-Rs1 + Rs [2])/(Rs[2] - Rs [3] ))*(ppmValue [3] - ppmValue[2]);
//PPM Ausgabe
delay(30000);
// Interpolation: ppm [15;24]
else if ( Rs[4] < Rs1 && Rs1 < Rs[3]){
float ppm = ppmValue [3] + ((-Rs1 + Rs [3])/(Rs[3] - Rs [4] ))*(ppmValue [4] - ppmValue[3]);
//PPM Ausgabe
delay(30000);
// Interpolation: ppm [24;28.25]
else if ( Rs[5] < Rs1 && Rs1 < Rs[4]){
float ppm = ppmValue [4] + ((-Rs1 + Rs [4])/(Rs[4] - Rs [5] ))*(ppmValue [5] - ppmValue[4]);
//PPM Ausgabe
delay(30000);
// Interpolation: ppm [28.25;32.5]
else if ( Rs[6] < Rs1 && Rs1 < Rs[5]){
float ppm = ppmValue [5] + ((-Rs1 + Rs [5])/(Rs[5] - Rs [6] ))*(ppmValue [6] - ppmValue[5]);
//PPM Ausgabe
delay(30000);
// Interpolation: ppm [32.5;37.75]
else if ( Rs[7] < Rs1 && Rs1 < Rs[6]){
float ppm = ppmValue [6] + ((-Rs1 + Rs [6])/(Rs[6] - Rs [7] ))*(ppmValue [7] - ppmValue[6]);
//PPM Ausgabe
delay(30000);
// Interpolation: ppm [37.75;43.25]
else if ( Rs[8] < Rs1 && Rs1 < Rs[7]){
float ppm = ppmValue [7] + ((-Rs1 + Rs [7])/(Rs[7] - Rs [8] ))*(ppmValue [8] - ppmValue[7]);
//PPM Ausgabe
delay(30000);
// Interpolation: ppm [43.25;48.75]
else if ( Rs[9] < Rs1 && Rs1 < Rs[8]){
float ppm = ppmValue [8] + ((-Rs1 + Rs [8])/(Rs[8] - Rs [9] ))*(ppmValue [9] - ppmValue[8]);
//PPM Ausgabe
delay(30000);
// Interpolation: ppm [48.75;53.25]
else if ( Rs[10] < Rs1 && Rs1 < Rs[9]){
float ppm = ppmValue [9] + ((-Rs1 + Rs [9])/(Rs[9] - Rs [10] ))*(ppmValue [10] - ppmValue[9]);
//PPM Ausgabe
delay(30000);
// Interpolation: ppm [53.25;57.75]
else if ( Rs[11] < Rs1 && Rs1 < Rs[10]){
float ppm = ppmValue [10] + ((-Rs1 + Rs [10])/(Rs[10] - Rs [11] ))*(ppmValue [11] - ppmValue[10]);
//PPM Ausgabe
delay(30000);
// Interpolation: ppm [57.75;62.5]
else if ( Rs[12] < Rs1 && Rs1 < Rs[11]){
float ppm = ppmValue [11] + ((-Rs1 + Rs [11])/(Rs[11] - Rs [12] ))*(ppmValue [12] - ppmValue[11]);
//PPM Ausgabe
delay(30000);
// Interpolation: ppm [62.5;67.5]
else if ( Rs[13] < Rs1 && Rs1 < Rs[12]){
float ppm = ppmValue [12] + ((-Rs1 + Rs [12])/(Rs[12] - Rs [13] ))*(ppmValue [13] - ppmValue[12]);
//PPM Ausgabe
delay(30000);
// Interpolation: ppm [67.5;75.5]
else if ( Rs[14] < Rs1 && Rs1 < Rs[13]){
float ppm = ppmValue [13] + ((-Rs1 + Rs [13])/(Rs[13] - Rs [14] ))*(ppmValue [14] - ppmValue[13]);
//PPM Ausgabe
delay(30000);
// Interpolation: ppm [75.5;77.5]
else if( Rs[15] < Rs1 && Rs1 < Rs[14]){
float ppm = ppmValue [14] + ((-Rs1 + Rs [14])/(Rs[14] - Rs [15] ))*(ppmValue [15] - ppmValue[14]);
//PPM Ausgabe
delay(30000);
else if( Rs[16] < Rs1 && Rs1 < Rs[15]){
float ppm = ppmValue [15] + ((-Rs1 + Rs [15])/(Rs[15] - Rs [16] ))*(ppmValue [16] - ppmValue[15]);
//PPM Ausgabe
delay(30000);}
else if (Rs1 >= Rs [16])
float ppm = ppmValue [16];
delay(30000);
else if (Rs1 < Rs [16])
float ppm = 80;
delay(30000);
delay(3000);
I don´t know what i´m doing wrong, but the values i´m getting are all wrong. It seems that this value aren´t from the analogpin.
Can someone help me?
Thanks
