Hello everyone, i'm trying to get this project to work properly. My transmitter is an arduino nano, connected to a ld2410 sensor which gives data about whether there's a human in range, his state, and at what range he is. This data is then sent to the receiver via nrf24l01, which prints it on an lcd and updates the distance. What i need to add, is the possibility to disable the transmitter ld2410 sensor, via a button on the receiver. The transmitter will transmit its data, and then listen for a short while, to ensure it can receive the necessary packets. However my button is giving me an inconsistent behaviour: While it is set to only trigger after a long press (1000ms), once i even press it for a minimal amount of time, somehow makes the receiver start receiving modified data, you'll see what i mean in the code section later. Long presses instead freeze the code, for a reason to me unknown. I would love any kind of feedback, cheers!
Transmitter code:
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <ld2410.h>
// nRF24L01 pins configuration
#define CE_PIN 7
#define CSN_PIN 8
RF24 radio(CE_PIN, CSN_PIN);
const byte address[6] = "00001"; // Address for communication
ld2410 radar;
unsigned long lastReading = 0;
unsigned long lastSwitchTime = 0;
bool radarEnabled = true; // Flag to control radar
bool listeningForControl = true; // Flag to switch between listening and sending
Serial.begin(256000); // Initialize hardware serial for radar
Serial.println("Initializing radar...");
bool initialized = false;
for (int attemptCount = 0; attemptCount < 10; attemptCount++) { // Retry initialization up to 10 times
if (radar.begin(Serial)) { // Initialize LD2410 radar module with hardware serial
initialized = true;
Serial.println("Radar initialized successfully.");
break; // Exit the loop if initialization succeeds
Serial.println("Radar initialization failed. Retrying...");
delay(500); // Wait 500ms before retrying
if (!initialized) {
Serial.println("Radar initialization failed after 10 attempts. Exiting setup.");
// Handle initialization failure here, if needed
// Initialize nRF24L01 communication
Serial.println("Initializing radio module...");
radio.begin();
radio.setDataRate(RF24_250KBPS);
radio.openWritingPipe(address);
radio.setPALevel(RF24_PA_MIN);
// Print radio module details for debug
radio.setAutoAck(false);
radio.setChannel(115);
radio.printPrettyDetails();
radio.startListening();
Serial.println("Radio module initialized.");
// Switch between listening for control and sending data every second
if (currentMillis - lastSwitchTime >= 1000) {
listeningForControl = !listeningForControl;
if (listeningForControl) {
Serial.println("Switched to listening for control messages.");
radio.stopListening();
Serial.println("Switched to sending radar data.");
lastSwitchTime = currentMillis;
if (listeningForControl && radio.available()) {
char controlMessage[10];
radio.read(&controlMessage, sizeof(controlMessage));
Serial.print("Control message received: ");
Serial.println(controlMessage);
// Parse control message
int controlFlag;
if (sscanf(controlMessage, "CTRL:%d", &controlFlag) == 1) {
radarEnabled = controlFlag;
Serial.print("Radar enabled: ");
Serial.println(radarEnabled);
// Only process radar data if the radar is enabled and not listening for control messages
if (!listeningForControl && radarEnabled && radar.isConnected() && millis() - lastReading > 800) {
radar.read();
lastReading = millis();
if (radar.presenceDetected()) {
Serial.println("Presence Detected.");
if (radar.movingTargetDetected() && radar.movingTargetDistance() < 10000) {
int distance = radar.movingTargetDistance();
Serial.println("Moving Target Detected.");
Serial.print(F("Moving target: "));
Serial.print(radar.movingTargetDistance());
Serial.print(F("cm energy:"));
Serial.print(radar.movingTargetEnergy());
// Prepare the data to send over nRF24L01
char dataToSend[50];
sprintf(dataToSend, "Target Dist: %d cm", distance);
// Print the data to be sent for debugging
Serial.println("Data to be sent:");
Serial.println(dataToSend);
// Send data over nRF24L01
bool success = radio.write(&dataToSend, sizeof(dataToSend));
if (success) {
Serial.println("Data sent successfully.");
Serial.println("Failed to send data.");
// Wait for a brief moment to prevent rapid consecutive transmissions
delay(1200);
Serial.println("No Moving Target Detected.");
Serial.println("No Presence Detected.");
Receiver Code:
#include <SPI.h>
#include <RF24.h>
#include <LiquidCrystal.h>
#define CE_PIN 7
#define CSN_PIN 8
// LCD pin configuration
LiquidCrystal lcd(9, 6, 2, 3, 4, 5); // RS, E, D4, D5, D6, D7
// Button pin
const int buttonPin = 10; // Pin for button
// State variables
bool buttonPressed = false; // Button press state
unsigned long buttonPressTime = 0; // Time when button was first pressed
const unsigned long pressDuration = 1000; // 1 second press duration required
bool displayState = false; // False for "O", True for "I"
bool radioEnabled = true; // State to track radio transmission enable/disable
Serial.println("Initializing receiver...");
// Initialize the LCD
lcd.begin(16, 2); // Adjust this based on your LCD dimensions (cols, rows)
lcd.setCursor(0, 0);
lcd.print("Sen1: xxx cm");
lcd.setCursor(15, 0);
lcd.print("O");
SPI.begin();
if (!radio.begin()) {
Serial.println(F("Radio hardware not responding!"));
while (1) {} // Hold program in infinite loop to prevent subsequent errors
radio.openReadingPipe(1, address); // Use pipe 1 for reading
radio.printDetails(); // Print module details
// Set button pin as input with internal pull-up resistor
pinMode(buttonPin, INPUT_PULLUP);
// Check button press
checkButtonPress();
if (radioEnabled && radio.available()) {
char receivedMessage[32] = {0}; // Ensure buffer is large enough
radio.read(&receivedMessage, sizeof(receivedMessage));
// Print received message to Serial Monitor
Serial.print("Received data: ");
Serial.println(receivedMessage);
// Extract and display distance from received message
int distance = 0;
if (sscanf(receivedMessage, "Target Dist: %d cm", &distance) == 1 || sscanf(receivedMessage, "Target Dist: %d cm", &distance) == 1) {
lcd.setCursor(6, 0);
lcd.print(distance);
lcd.print(" cm");
Serial.println("Invalid message received.");
delay(2000); // Delay before clearing LCD for next display
lcd.setCursor(0, 1);
lcd.print(" "); // Clear the second line
void checkButtonPress() {
// Read the button state
int reading = digitalRead(buttonPin);
if (reading == LOW) {
if (!buttonPressed) {
buttonPressed = true;
buttonPressTime = millis();
if (millis() - buttonPressTime >= pressDuration) {
// Button has been pressed for at least 1 second
displayState = !displayState; // Toggle the display state
radioEnabled = !radioEnabled; // Toggle the radio enabled state
updateDisplay(); // Update LCD to reflect the state
// Debug message
Serial.print("Button pressed, displayState: ");
Serial.println(displayState ? "I" : "O");
Serial.print("Radio state: ");
Serial.println(radioEnabled ? "Enabled" : "Disabled");
// Reset button press state to avoid multiple triggers
buttonPressed = false; // Reset the button press state if the button is released
// Function to update the LCD display
void updateDisplay() {
if (displayState) {
lcd.print("I");
lcd.print("O");
Expected output Receiver:
Received data: Target Dist: "xxx" cm
Output after short button press:
Received data: �������������������������������K
Received data: BTarget Dist: 63 cm
