I want to ascertain rpm of a small wheel approx 20mm dia. This wheel is driven by another gear. I will then multiply by a ratio to give me output in screen. Need to be able to change ratio in code easily or have say 3 or 4 preset ratios. With buttons to select.
What is the best sensor to use for the rotation of 20mm wheel, IR, or hall effect. Needs to be smallish. Up to 200 rpm.
Is there any code available to take output from sensor and multiple as required on to display screen. Color or LCD, or LED 7 seg. 2 digit speed up to 99.
Thanks for the links. I will go for the board version. Hope I can locate here in New Zealand otherwise Amazon. The smd looks good and small. Do not have the ability to use this.
I will have a go at the coding, lots of examples around sso I should be able to mix and match something.
Thnaks
Charles
